Question about Keurig Platinum B70 Coffee Maker
I have a Keurig Platinum B70. When it brews, instead of letting water into the k-cup, it dispenses hot water back into the water resivour. What's wrong?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
I have a Keurig B70 that worked perfect till this morning. It quit despersing water ,what can I do?
I would start with the basics. Get the quick start manual and follow the instructions. If that does not work then the pump or controling circuirty has failed. I have attached a link for the quick start guide.
Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
You can also contact customer service at: 1-866-901-BREW Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
Mar 02, 2015 | KUERIG Keurig Platinum B70 Brewing System
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
Jul 27, 2014 | KUERIG Keurig Platinum B70 Brewing System
Cup not filling up
There are 3 needles on the underside of the lid and one on the bottom of the kcup holder. Using a thin "uncoated" paper clip, straighten the clip and insert it into the hollow needles and then run a 4oz cup of hot water (NO Kcup}. Repeat until NO more grounds are dispensed. Dave
Mar 04, 2014 | KUERIG Keurig Platinum B70 Brewing System
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
While brewing the hot water is returning to the cold water side instead of going through the k cup.
heatman101
Apr 21, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Platinum is clogged
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
B70 says it is brewing. Hear it draw water but it
on my fourth machine...just call keurig...they will replace it. THEN use only bottled drinking water (buy at store buy the gallon). I have done this for over a year now without any problems. Apparently my water had some hardness to it that plugged the line internally. My machine would draw a little water and no water would come out and the default cup size was set to large and could not change. I guess because the internal resivour (sp) was already full and there is no way to empty it.
Feb 01, 2010 | Keurig Platinum B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
846 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
