Question about Vizio GV42L 42 in. LCD Television
What bolt size to mount a 32 inch tv to the mount? 4 bolts and where to get them?...Thanks...Glenn
budmrtn
  • 11361 Answers
SOURCE: size of wall mount bolts
Metric M5, try place like Home Depot or Lowes, they are about 50 cents each so you can get different length depend on the thickness of the brackets. Please notes that some version can be as big as M6.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jan 03, 2011
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
SOURCE: Mounting TV
They are a metric size, call Panosonic, I belive 8 x 15mm
Posted on Dec 31, 2007
  • 146 Answers
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Posted on Jan 30, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
REAR SCREW SIZE TO HANG TV MOUNT
try your local hardware store, use a pencil as a guide to help size the bolt needed, you might need to buy a few different sizes, but make sure it's the right tread ! you can return the bolts not used, you need 4 bolts total and there mostly metric.and a certain length DO not use long bolts !
If hanging the mount on the wall, once again ask your local hardware store guy for assistance, these tv's are heavy and need to be mounted properly, and can kill if they fall. so do it right !
Sep 03, 2015 | Hisense 55K22DG 55-inch 1080p 120Hz MHL &...
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
What size bolt for gas pedal on 1996 ford explorer
If to mount to the floor pan, they are usually in the neighborhood of 3/32 to 1/4 inch shank self tapping bolt. It should have either an 8mm head or a 10mm head.
Jan 27, 2012 | 1996 Ford Explorer
Screw size to bolt panasonic 32 inch lcd into
Dec 23, 2009 | Televison & Video
There are no bolts to mount my Samsung Series 6 to my TV Stand
YES TAKE THE SMALL BOLTS WITH YOU AND GET LONGER ONES
Aug 24, 2009 | Samsung Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
Best of luck.
Jan 30, 2009 | Televison & Video
ILO 32" LCD
yes it is mountable. the 4 bolts are metric size is 6mm -1.0 x 40 mm
Use are large tv wall mount unit and buy the bolts seperately. I just hung mine and the
only problem I am having is I cannot remove the table top mount off the bottom of my TV
Can you halp??
Mar 29, 2008 | iLO 3200 32 in. LCD Television
Dont know what size bolts to use for fixing brackets to tv to wall mount a 26 inch wharfdale l26ta6a
you should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
Mar 04, 2008 | Televison & Video
Mounting TV
Assume you are mounting on the wall, if so a good mount will have the standard bolts in the package. If this is a used mount, you will need to determine the length based on the mount, the bolt size is either 1/4" or 5/16", probably the latter.
Dec 14, 2007 | Panasonic TH-50PX75U Plasma HDTV
Vizio GV42L 42 in. LCD Television Logo
285 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
