Question about Rival Heating & Cooling
Rival 4000 Watt heater, #T268. Motor is making noise and need to replace. Where do I purchase a replacement heater for above model.
Therinnaiguy
  • 1420 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
Sounds like a bad temperature control switch. If it looks like it can be replaced, check with Johnstone or Grainger Supply company to match it up. Google it for their websites.
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: Replacement cover for Rival 38601 Crock Pot
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
Posted on Jul 09, 2008
SOURCE: How do I replace a Heater Blower motor in a 2003 Pontiac Vibe?
Remove the Glove box. You will then have access to the Blower unit. There are 3 screws that are holding the blow unit in place. You will need a Phillips screw driver and a 1/4 socket. Once you have located the unit remove the 3 screws and the unit will fall straight down. Unplug the wire harness and then reinsert the new Blower Motor. If you purchase an original GM part this makes life much easier, you just screw the 3 screws back into the holes and then plug the wire harness back in and reinstall the glove box. If you use an aftermaket part you will need to do some wire splicing to make it work but it is a 10 to 20 minute job depending on which part you decide to replace the Blower with.
Posted on Feb 04, 2009
Deneenie
  • 73 Answers
SOURCE: Need replacement lid for Rival crock pot
OKAY...I'll help you figure this out
Rival doesn't even acknowledge that model number (3154) in their replacement parts. Makes me think we either have the wrong model # or the wrong manufacturer OR more likely we are missing a few of the prefix letters to the model number.
Please double check and make sure you are looking in the right place for it...here's a pic on Rival's website on where to look on the crockpot: http://www.crock-pot.com/CustomerService.aspx?id=rpt
If you are certain it's a Rival and the number is "3154" then call their customer support # at 1-800-323-9519.
If you discover the model number does have a few prefix letters, be sure to enter that on their search page (which is the same link I posted above.)
Not sure what the replacement part will cost but for $35 you can get a used 3154 with lid on ebay: here (that kinda proves there is such a model - so you may have to call Rival at the number listed above.
If this solves it for ya, please let me know by rating this answer. If not let me know. :-)
Posted on Mar 29, 2009
SOURCE: air conditioner and heater makes loud noise when turned on.
This might be the noise problem in your blower.The blower is out of balance with this added weight.5610f51.jpg
Posted on May 16, 2009
Mar 29, 2009 | Rival 3145 4.5-Quart
Rival Mfg. Co Food Slicer 1101E/7 - replacement screws
1101E part number for thumb nut 994-572, threaded shaft 995-254, blade 993-386, idler gear 348-077, washer 854-023, these are the Rival part numbers from the orginal owners manuel
Dec 09, 2008 | Food Processors
Humming noise in amp
You must break it down through a process of eliminating items. With the system running unplug the RCAs from the amp. Do you still hear the noise? Try turning the gain down on the amp a bit and increasing the subwoofer level on the head unit instead. Make sure you have a low pass crossover set (probably below 80Hz).
Does the noise change with engine RPM?
Try a different RCA cable. I find that most times noise filters will make the problem worse not better. If none of the above things work, check that the grounds within the car are good, battery to frame, to engine block and chassis. Sometimes a bad vehicle ground is the cause. If all else fails, hook it up to someone else's system and see how it works.
Oct 07, 2008 | Car Audio & Video
Handle on crockpot lid broke off.can I replace it at store where purchased?
I have had the same problem. Spoke to rival customer service and they no longer sell replacement lids for model number SCE502. I've read to take the screw from the knob to a hardware store and then find a knob which will fit it.
Someone else suggested that if the knob is mostly intact, ask hardware store for araldite glue
Dec 08, 2007 | Rival 3755 5.5-Quart
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Where to purchase filters?
http://www.rivalproducts.com/category.aspx?cid=1124
according to the rival web site, purchase the filters for the r22 model and cut to size. site above purchase price 9.19 but can also purchase from Walmart.
Nov 03, 2007 | Rival CF275 Deep Fryer
Heating & Cooling Logo
176 people viewed this question
Top Rival Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Rival Heating and Cooling Expert? Answer questions, earn points and help others
