Noise in washer need to know how to remove agitator
  • brooomfieldb Aug 01, 2008
    I'm trying to figure out how to remove the agitator in my Whirlpool top load washer. The instructions that I have say simply to insert a screwdriver into the outer cap or dispenser and pop it off. The cap that I have to remove is one piece...and I have been trying to pry off the whole top portion...the 2 inch or so upper cap...but with no success. Can someone help me here???
    Thanks!
    Bill
  • 246 Answers
For most Kenmore, Whirlpool, Estes, Maytag, and some GE washers the top portion of the agitator can be pried off (either a cap or fabric sofrtner dispenser depaneing on make and model) and there is a bolt underneath. Once removed, the agitator can be lifted straight out. Some GE's you have to actually "pop" the agitator by placing a strap underneath and lifting it out that way. If your are still having trouble, reply back with your model and serial number and we can go from there.
Posted on Jun 19, 2008
Kenmore 80 series washer is making a noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.
Jan 25, 2010 | Kenmore Washing Machines
This Kenmore Elite Top Load Washing machine has
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 26, 2009 | Kenmore Washing Machines
Kenmore 8288100 will not agitate properly, i replaced the dog ears but that did not solve the problem. It also makes a loud noise during the agitate cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine. Sears has a parts list for model 82881100.
It's hard to diagnose what "will not agitate properly" means. However, since you've replaced the dogs and are getting a loud noise during the agitate, try to isolate where the noise is coming from.
Remove the cabinet, see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
If you jumper the two outside pins on the lid switch you will be able to start the washer and listen to the agitating. (We used a couple of bunge cords to keep the back of the washer from flopping around)
When it begins to agitate, listen closely to the transmission. If the noise appears to be coming from the transmission, the problem may be in the agitate cam and / or gear in the gear box.
Look at the gear box diagrams on the Sears site.
We had a major noise problem with our top loader and traced it to worn agitate cams.
Pulling and replacing parts in the transmission is a messy job (14 - 15 Oz. of oil) but it can be done.
Following is how we replaced the cams.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Sep 25, 2009 | Kenmore Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Agitator make noise
u will need to replace the washer trnsmission
Jul 16, 2009 | Washing Machines
Won't spin, just makes rapid clicking type noise
Hi, Do you hear a chattering noise when the washer should be spinning?
Do you know if the washer agitates? If the washer does not spin or agitate it sounds like a coupler could be bad.
Let me know if I can assist you further.
VIc
Jun 04, 2009 | Roper RAS8445KQ Top Load Washer
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Agitator started making noise
pull the softener cap off and look in the hole there are plastic toothed pieces that wear out and need to be replaced. agitator dogs.
Jan 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
