Question about Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet
I have a Devonshire kohler k-393. I want to replace the washer under the elbow and can't figure out how to remove the elbow?
My kohler toilet tissue holder came off the wall...how to you separate it from the metal wall mount to rescrew it into the wall...it looks like a special tool is used..
Hello - most toilet tissue holders have a allen screw head or a eye glass screw head that holds them together, they need to be separated,remounted to wall then put back together. P2 Plumber 25 yrs
May 18, 2011 | Kohler 10554-BRZ Devonshire Toilet Tissue...
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
Low pressure and diverter not staying on
remove the temp handle first decorative handle then brass sleeve under that brass should slide straight out you will see the mixing housing witch is brass cup shape piece about the size of washing powder cap there will be a small black plastic screen there pull out clean and replace then put back together should have good pressure which will fix diverter problem
Oct 01, 2010 | Kohler K-T396-4-BRZ Devonshire Single...
How do you remove the handle assembly from Kolher Devonshire bath faucet model?
Pry off the little red / blue plug and use an allen wrench to loosen the screw
Feb 20, 2010 | Kohler Model 10433: FortĀ® Single-control...
We have a Devonshire pedalstal sink that is clogged and we can't snake with the P trap it just gets hung up. Plunging hasn't worked. Any ideas?
You need to remove trap and rod from the wall opening I have had to remove many pedestal sinks in order to rod the drain
Nov 15, 2009 | Kohler K-3488-0 White Devonshire...
The water jet pump wont turn off or sometimes turns on by itself
go online to kohler and they will send you out a new switch,, it isn't that hard to install, this will solve your problem and I think if you tell them it was put in not to long ago they will send it for free
Apr 03, 2009 | Kohler Devonshire 5ft Drop-In Bubble...
Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet Logo
182 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
