Question about Fantom Vacums Lighting Canister Vacuum
Need to get lower wand . where can i order - Fantom Vacums Lighting Canister Vacuum
    Novelist:
  • 147 Answers
Your best bet would be to check Ebay for anything like that for that machine. Not only has it been discontinued, there are no parts (new) available.
I just searched, and Ebay has one for 15$.
Good luck.
Posted on Nov 15, 2010
No power
Those have a tendency to short out in the wands. Use a test light or meter to find out where the power stops. Test lower wand first then upper then hose, then unit. Replacement wands are available, there's really no fixing them. I'll include a link to the wands I'm referring to.
Good Luck!
Lower (most common)
http://www.vacuummedic.com/product.php?id=452
Upper (very common)
http://www.vacuummedic.com/product.php?id=450
Feb 12, 2013 | Kenmore 25512/ 25513 Progressive Canister...
Belt not turning
Good Luck!
Lower (most common)
Upper (very common)
Feb 07, 2013 | Kenmore 25512/ 25513 Progressive Canister...
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
http://www.govacuum.com/miele-172.html
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
The attachment that holds the Dyson crevic tool broke. What part do I order to replace it?
You need to replace the wand. To find the wand appropriate to your machine, visit http://www.espares.co.uk/dyson/dc04/p/1086/716/4
Aug 10, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Wand
I just took my DC17 apart to determine the problem (noted above). Basically it seems like there is a 'nub' on the lower part of the extension wand. Actually, there are two on either side, one higher (white, facing the back) than the other (black, facing the front). The lower one (black) acts as a brake for when you yank the wand out - it stops the wand from coming out all the way. The little black nub is hitting the inside ribs of the hose and stopping, impeding the wand from pulling out. What seems to have happened is that the hose has constricted a little too much and the diameter is 'smaller' by just a little and therefore the nub catches. Use the trick I mentioned above to work the hose off, a little at a time. Once you get enough hose, you can stretch the hose and it will then pull out without catching. To keep it from doing it again? I am not sure, but if you were to turn the wand/hose counter-clockwise to loosen the coil inside the hose, this may just open up the inside a little bit. I have done this and it is seeming to work. So every time I use the wand, I will unwind the hose counter-clockwise a little bit and see if this helps....
Jul 18, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Panasonic performance plus platinum vacuum cuts off and on while using the beater bar, this doesn't happen at all using the stair cleaning attachment. It appear electrical contact is being lost where...
The solution to my problem which is located at the lower electrical plug on the long wand was to expermint using a nickel and placing this in an area where the long wand connects with the beater bar section, here there is a gap which allows too much clearance thus losing electrical contact at times and then making contact. A nickel is about .075 thousands thick so I hacksawed a flat piece of metal that was this same thickness, the other dimensions of this little piece are 3/8 inch wide by 5/8 in length, I then forced this little piece in the above mentioned gap which places tension maintaining electrical contact. It works fine now, there is either wear in the electrical contacts plug in, a new lower electrical plug in line will fix this but I can order one later I need to vacuum the whole house so now I can. Jon Olinger
Jul 09, 2008 | Panasonic Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Loose Wand Connection
its just worn, sometimes getting a new lower wand can fix this
Jan 18, 2008 | Vacuums
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Fantom Vacums Lighting Canister Vacuum Logo
29 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
