Question about Maytag Washing Machines
Hpburbah@sheMaytag stackable Model LSE7804ACE blows one amp fuse every 10-11 loads. Washer will not fill. Dryer works fine. Repairman can't find anyting wrong.
  • hpburba Nov 15, 2010
    The repairman from the appliance store where the machine was purchased is doing the repairs and replacing the fuses. Could the first fuse just wear-out? Maybe the replacement fuses were too small and that's why they keep blowing?
    President:
  • 1,891 Answers
You need to replace the lid sw and the kit comes with a 4 amp fuse . this should solve the problem. / now the sw is bad causing the fuse to blow because its worn out . .. hope this helps mm feed back pls ..
Posted on Nov 16, 2010
  • Maytag Master
  • 12,061 Answers
Hi, a ONE Amp fuse, to my mind, is NOT enough? are you sure they are not TEN AMP? Even a 5 Amp? maybe even a two?, but a one? You do need to check.
Your machine would use a normal to big fuse, 1 Amp at 120 Volts only equals 120 Watts MAX, I think you will find that you machine will draw more than that, especially when the motor cuts in? and also it needs some "Headroom" or it would "Blow" every time a "Load" was put on the fuse.
If it is blowing fuses, then the ONLY things that that can be, are an overload, or a constantly overloaded fuse, that eventually overheats and "Blows". And a Short Circuit.
However I suspect that it just maybe the fuse... and it does protect for 10 to 11 "Loads" then because of thermal stress "Blows"?
However IF it is NOT that then you MUST get an Electrician to test the machine, as any machine that Blows fuses also has the ability to make the Case "Live" and deliver a potential lethal shock. Please be careful.
Posted on Nov 15, 2010
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
No power is there a fuse in the dryer. The power is ok. Could it be the plug? It is at my summer home it is a stackable purchased about 3 years ago. I don't have the model. It was purchased at Lowes
There is a fuse in the dryer, its called a high limit sensor. If the dryer gets too hot the high limit blows like a fuse and saves your house.
Make double sure you have proper power at the outlet before you tear into the machine.
Good Luck
Quentin
Oct 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
I have a maytag stackable washer dryer model number LSE7800ACW when i turn on the washer it will not fill it will not spin it will not do anything but the dryer works just fine. What is wrong
HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
Oct 07, 2008 | Maytag Washing Machines
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
126 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
