Question about Canon Cameras
Canon PowerShot A85-suspect one of the flash card reader pin recepticle in the camera has a bent pin. Can it be repaired?
  • Canon Master
  • 4,738 Answers
It's not as hard to fix as as you might think. Remove batteries and card. Look in the card slot with some light to see if any of the pins are bent. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible (you can get a cheap set at the dollar store). Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jun 19, 2008
My canon camara keeps saying memory error
Just to be sure, you did try other cards right?
If so, Bent pins are quite common unfortunately. Can't wait until they come up with something easier for this. Fixing it yourself is possible, yet you absolutely need the right tools and to know what you are doing. There is quite a bit to dismantle before you get to that area. Camera repair can be done and this company is very good at it. They even have a blog on bent pins and it shows a picture of what this looks like. Picturehttp://www.fixya.com/uploads/images/6c7df8a.gif
Jul 24, 2010 | Canon PowerShot A75 Digital Camera
Cannot read comapct flash memory card
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Jun 28, 2010 | Canon PowerShot A60 Digital Camera
Unable to download pictures
In the short term you can take the memory card out and use a card reader - at least that will let you see the pictures.
Mar 21, 2010 | Canon PowerShot A85 Digital Camera
I have a Canon PowerShot G6 and every CF card I insert in the camera displays Memory card error 100-0002. Any idea why this is happening?
Jan 22, 2010 | Canon PowerShot G6 Digital Camera
My Canon powershot a80 will not come on.
It sounds memory card is defective and preventing camera to turn ON.
Check camera with another memory card or try this memory card in another Canon camera to confirm it.
Dec 09, 2009 | Canon PowerShot A80 Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
I have a couple broken pins in the compact flash connector internal to the camera. Can I order a replacement socket and attempt repair myself?
It can be done, but it's not easy and requires patience and a good invetory of parts and screws. Replacement card reader can be salvaged from a broken ebay camera (A75 and A85 readers are interchangeable). Here's a disassembly of a very similar A70:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Now are the pins actually broken or just bent. If just bent, you can actually and easily unbend them, but it requires patience:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Jun 24, 2009 | Canon PowerShot A75 Digital Camera
Says read error when i try to view pictures
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jun 09, 2009 | Canon PowerShot A85 Digital Camera
Canon eos30d
Bent/broken card reader pins. Take a flash light and look inside the card reader. There you'll see two rows of pins, 1or 2 will be bent (common problem).
Needs repair service.
Oct 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Canon A85 power on problem
I think we can rule out a problem with the cards, which leaves the camera. maybe one of the cf pins is bent?? look into the slot with a light and check for any pins out of line, if you find any, see if you gently push it back into place. I saw the exact same problem, having the same fix. try also connecting AC through a cable and the camera to the computer, see if it makes any change. Whats your warranty status? use it if you still got it, if not, get a repair estimate. Hope it works out
Feb 12, 2006 | Canon PowerShot A85 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
