Question about HP LaserJet 4350 Printer
Please tell me how to configure ip address in printer 4350
  • 28 Answers
Press Check mark (SELECT button) to open the menus.
2. Use (UP button) or (DOWN button) to scroll to CONFIGURE DEVICE menu, and then press
(SELECT button).
3. Use (UP button) or (DOWN button) to scroll to I/O submenu, and then press
(SELECT button).
4. Use (UP button) or (DOWN button) to scroll to EMBEDDED JETDIRECT MENU
5. Use (UP button) or (DOWN button) to scroll to TCP/IP
Then: Select whether the TCP/IP protocol
stack is enabled or disabled. You can set several
TCP/IP parameters.
Select the TCP/IP CONFIGURE METHOD to
configure the EIO card. For the MANUAL option,
set the values for IP ADDRESS , SUBNET
MASK , LOCAL GATEWAY, and DEFAULT
GATEWAY
Posted on Nov 14, 2010
After manually entering new IP address on HP laserjet 4350 it goes back to the old one
sounds like maybe you have boot or dhcp set to on when it should just be set to manual, are you changing the ip from the machine or from webjet admin window? you could also check your network settings to make sure there isnt a special rule written for that particular mac address of the printer, it would override anything you try I believe...hope this helps...
May 11, 2012 | HP LaserJet 4350 Printer
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
How to update a new ip address in order to get my printer print?
I think IP address is not a problem in your printer. You just need to check if the printer driver is install to make your printer work...
IP address is only use to connect the computer to the internet not to connect with the printer. If you have a printer connect to other computer you really need to configure the IP of both the pc to connect each other...
Router will automatically assign IP address of those computer connected to a routers. If you still not connect
Please don't hesitate to ask again and I will give you the step by step to configure your IP address unless your connect with static IP
Sep 20, 2011 | Xerox Phaser 6125 Laser Printer
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
How can i configure a ip printer on network
The first thing you need to do is plug in the power and the Ethernet connection. All network-capable HP printers and JetDirect appliances will default to DHCP mode, which automatically acquires an IP address on any DHCP-enabled network. Even tiny home networks with inexpensive routers have automatic DHCP-assigned IP addresses. Once the printer comes online, it will automatically obtain the first available IP address in the DHCP pool.
Next, you need to figure out what IP address the printer automatically obtained. There are multiple ways to do this. The surest way is to get the printer to tell you what the address is by printing out a network configuration printer report. You'll have to cycle through the options on your particular HP printer to find and print the configuration report. On an HP 4250 for example, you would push Menu, Information, and then Print Configuration to get it to tell you what IP address it's sitting on. The external JetDirect appliances have a button you can press to print the configuration.
If you don't want to or can't physically touch the printer because it's in some remote location, that's not a problem. If you happen to know what the DHCP range is or you can look at the DHCP server itself, you'll quickly be able to see what IP address the printer obtained. If it's a relatively empty network, you can ping the first available IP in the DHCP range and find the printer that way.
Once you know the IP address of the printer, it would be possible to declare you're done and just print to that dynamic IP address. But from a management perspective, you may not want to do this because you want the printer on a fixed and predictable IP address. Really smart network administrators will create static DNS names for the printer and have people point to the name of the printer instead of the IP address. That way, if the printer ever needs to be moved or needs a new IP address, you won't have to change all the servers and workstations pointing to the raw IP address. You can just change the DNS entry in one place and everyone will automatically divert to the new IP address. But before you can assign any DNS entries, you must change the DHCP address.
Changing the IP address
If you want to change the IP address to something static, you can do it via Web interface or command line interface (CLI). But by the time you even start the Web interface, you could be all finished if you used the CLI. We're going to stick with the CLI here because it requires only a few quick commands.
For the purpose of this tutorial, let's say that the printer obtained an IP address of 10.1.1.10 and you want to change it to 10.1.1.100. All you need to do is open up a command prompt and type telnet 10.1.1.10. To change the IP address, type ip: 10.1.1.100.Type exit, and it will ask you whether you want to save the settings. Just press Y to apply the changes.
Let's say you want to take an existing printer that's on 10.1.1.100 and move it to a completely different subnet. Instead of following this entire procedure, just telnet in and change the IP configuration to the new settings before you power down and move the printer. Then, once you plug in the printer to the new network, it will already be ready to go and accessible.
Suppose you want to change the IP address to 10.1.2.100, the subnet mask to 255.255.255.0, and the default gateway to 10.1.2.1. You'd type the following series of commands:
  • telnet 10.1.1.100
  • ip: 10.1.2.100
  • subnet-mask: 255.255.255.0
  • default-gw: 10.1.2.1
  • exit
  • y
That last Y key commits the changes, and you will lose the ability to access this printer until you reattach it to the 10.1.2.0/24 network. But once it's reattached, you won't have to go through the whole setup routine of determining the DHCP address and changing it because it will already be configured to 10.1.2.100.
Nov 02, 2010 | HP Office Equipment & Supplies
I am trying to locate the ip address on an office hp 4200n
Usually you can print a configuration page and it will tell you the IP address that is assigned to the printer. You should be able to use the small menu screen on the printer to navigate to, and print a configuration page, or use it to navigate to the network settings to view and/or edit the current configuration. If all else fails, sometimes you can run Angry IP Scanner on a computer that is on the same network as the printer and see if any of the hosts come up with a name that matches the printer, then you will see the address of that host.
Jul 20, 2010 | HP LaserJet 4200 Printer
How do I set the IP address on my HP 8150
1. Launch your web browser.
2. In the Address: or Go to: field, type the IP address assigned to the
printer (for example: http://192.168.1.1) or the host name (for example:
http://myprinter).
If you do not know the IP address for the printer, it is listed on the
printer configuration page under Protocol Information in the TCP/IP
section.
To print a configuration page:
a. On the printer control panel, press Menu until INFORMATION
MENU displays.
b. Press Item until PRINT CONFIGURATION displays.
c. Press Select to print the configuration page. After the process is
completed, the printer will return to the READY state.
From there, you can configure the printer using the web GUI. Consult the manual if you need at:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl10150/bpl10150.pdf
Hope this helps, and have a good weeked.
Dec 12, 2008 | HP LaserJet 8150 Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
HP LaserJet 4350 Printer Logo
1,579 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
