Question about Sony Playstation 3 (PS3) Console
Can't switch the standard display setting to hdmi setting keeps going back to previous setting.
You dont have a HD tv, there needs to be constant communication between the tv and ps3 which a normal tv dont deliver.
Posted on Nov 14, 2010
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I am trying to connect a playstation 3 to my tv using a hdmi cable but it says "no support". i can hear it but there is no picture.
Try connecting it using HDMI and the standard composite video. Then when you press the power button on the PS3, Press and hold it, it will beep once for turning on, then beep again, once you get the second beep, release the button. Switch your TV to the composite mode and go to your display settings. Then change your display settings to the HDMI cord and the screen will most likely go black. Then switch your TV to the HDMI mode and finish the settings change. Then, change the audio settings to audio as-well. Hopefully this helps. Nathan Taylor.
Jul 17, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
How do i hook up my ps3 with tv through hdmi as it keeps goin to blue screen
  1. Connect the PS3 standard composite video connector (yellow RCA plug) to the TV composite input and switch the TV to that input. Leave the HDMI cable connected.
  2. Make sure the PS3 is off. Turn it on and hold the power button until you get two beeps (at least 5 seconds). The PS3 navigation screen should be shown on the TV. If not, switch the TV back to HDMI; the screen should be displayed at 480i resolution.
  3. Go to the settings menu. Select Display Settings, then Video Output Settings, then press the X button on your controller.
  4. The on-screen instruction should be "Select the type of input on your TV." Select HDMI, then press the '> (solid right triangle) button on your controller.
  5. You will be offered the choice of Automatic or Custom settings. Try Automatic first (if there is a problem at the end, start over and pick Custom the second time).
  6. Press the X button. You will get a screen asking you to confirm the changes. Press the X button again to confirm.
  7. You may get a screen asking for the resolution setting. IMPORTANT: if your TV's maximum resolution is 720p or lower, do not pick a higher resolution. The TV may not display properly or may not display at all (blue screen). Pick the highest resolution your TV can display.
  8. Confirm this by selecting "Yes" and pressing the X button.
  9. The settings list should now read Connector Type HDMI; Resolution Standard (NTSC); 480p; 720p; 1080p (if applicable). Press the X button to confirm.
  10. You may be offered a choice of audio outputs; you can use HDMI or something else, depending on your setup. Confirm the setting and press X one more time.
At this point, the PS3 should send its signal to the HDMI port following restart. If your TV has more than one HDMI input, make sure you select the one connected to the PS3.
Mar 12, 2011 | Televison & Video
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
The PS3 switches on, lights up, drive and disc drive working but No Signal on TV. Saw HDMI cable solution previously posted. Does that work for SCART also?
yes just change hdmi for the word scart
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Switch my playstation to hdmi.. Played switched it back cant get any picture
Please try the following to reset the display settings back to standard.
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep.
Wait for the PS3 display to be reset
Hope this helps
May 23, 2010 | Sony Playstation 3 (PS3) Console
XBOX Live plays back with pink hue
*YOU DO NOT NEED TO SWITCH TO STANDARD DEFINITION*
To view the videos via HDMI, you need to switch the HDMI Color Space setting to "RGB". To do this go through:
My Xbox > System Settings > Console Settings > Display > HDMI Color Space > and from there select RGB
I had this same issue when watching movies from a USB flash drive and this worked perfect, so I hope this helps those of you who love your HDMI as much as I do.
Aug 17, 2009 | Microsoft Xbox 360 Console
How to hook my sony VAIO to TV via HDMI
Hi there Dream,
There is a toggle function for switching the display. It cycles from normal to external to both.
You are looking for one of the F-Keys (Normally F5) should have a little rectangle between two vertical lines. It's supposed to be a monitor.
To cycle the display, press the Fn key (near the space bar), then the F-key. Your standard display should go blank. To get it back, do the same thing.
If your TV still displays nothing, Check which input its using.
This should get you going.
Mike
Dec 08, 2008 | Sony VAIO VGC-RB42G PC Desktop
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
