Question about Ovens
I have a GE517 oven, the range works fine but the oven does not work at all, when it went out it worked sporadically for several weeks. Now when you turn the knob nothing happens at all. There is no sounds and no fas smell either.
  • 218 Answers
Remove the bottom oven panel (2 screws at back bottom)and see if ignitor glows if it does it may just be weak replace it if not check for 120vac if it has 120vac replace ignitor if not then Unplug power and check for loose or broken wires. trace wire to find out why it is not getting power to ignitor. If you are not familiar with tracing ans testing electrical I would recommend calling out a service tech.
Posted on Nov 14, 2010
Top convection oven not heating. Seems to occur sporadically but more often won't heat. I sent the 2 relay boards and oven display board out for analysis and repair. I am still having the problem.
One of the first things I check on any heating device besides the element is the High limit switches that only allow the element to work if the heat stays below a certain degree range. They areon furnaces, dryers, wall heaters, etc. They usually look the size of a small coin abouit 3/4 -1" with little wings on the side to for screws to secure them. That may be your problem.
Dec 01, 2015 | Thermador SC302T Electric Double Oven
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
KitchenAid gas range - Err message F5 E7 - cannot unlock door
Normally when storms hit your oven, the electronic control board goes out. That's what has happened to this oven.
Oct 24, 2009 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
When using oven it beeps and displays f3
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
Mar 15, 2009 | Kenmore Ovens
Thermador oven problems
Greetings, this JUST happened to me.
The solution was to break the circuit at the breaker panel for 1 minute, reset the clock, and the unit seems to work now.
Nov 20, 2007 | Thermador Ovens
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
