Question about Sunpentown 11 in. SR-1330 Electric Cooktop
Light blink and fan working but not hot or warm
New microwave that is not an outside exhaust. The fan works but there is not suction from bottom of unit? Also is this fan supposed to come on when there is hot steam coming up from the stove below?
Hello friend, thank you for your post!
From my understanding you have some questions regarding the operation of your Frigidaire microwave. The fan will turn on when the temperature sensor recognizes the temperature is too hot. There should be suction from the bottom. If you are experiencing issues with your new microwave I would recommend contacting your manufacturer for proper warranty coverage. I hope this information is helpful to you. -Matt
Dec 27, 2015 | Frigidaire FGMV174KF 1.7 Cu. Ft. 1000W...
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
After fan is on for awhile the motoe feels hot to the touch..Why??
That is because small motors like this are very inefficient.
Almost everything in nature that has inefficiency throws off energy as heat.
The motor is probably throwing off 100 watts of waste heat total, which compares to the heat of a 100 Watt light bulb, so getting hot is not surprising.
Dec 15, 2009 | Jenn-Air JED8230 Electric Cooktop
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
The fan runs and then shuts off. The light on one dial ''blew''
the white wire from the stove top goes to the green wire or nuteural, the red and black go to the hot wires I had the white wire from the stove top going to the hot wire and I had the same problem as you. am lucky I did not burn up my motor.
Dec 06, 2008 | Jenn-Air JED8430 Electric Cooktop
My jenn air cooktop only gets warm and only has 110 volts?
how old is the cooktop? may have a broken or disconnected wire in it.
Oct 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Electical problem?
You really shouldn't have tried this. If you mixed up the neutral and hot wire YOU COULD HAVE BEEN KILLED!!!! You also could have burned out the fan motor. The fan operates on 120 volts the rest on 220. On most cooktops the frame is grounded to the neutral. If you connected this wrong the entire outside of the cooktop could be live. You might not be shocked if you have on rubber shoes but if you touched the stove barefooted you could be killed! The house wire should have 2 hot wires usuallly black or red. It really doesn't matter which is which. There should be a neutral (usually white or bare) There can also be a seperate ground wire (usually green or bare) If only 3 wires from house connect the white and green together. The minimum wire size should be #10 fused at 30 amps. Test the voltage between the 2 hot wires. It should be 220. Between either hot wire and neutral or ground should be 110 volts .. IF YOU DON"T KNOW WHAT YOU ARE DOING CALL SOMEONE ELSE. This is very dangerous if hooked up wrong.
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Old jennair cooktop
The wiring diagram is pasted on the inside of the panel you remove to get to the wiring. If no wiring diagram The blower operates on 110 volts not 220 So the wire goes from one of the hot sides (Black or red) to the switch controlling the fan to the motor , from the motor to the neutral (white/Bare) wire terminal. Pilot light for fan is attached to the same wires as the motor. If you don't know what you are doing disconnect all wires from the burner switches to the fan motor. This will mean you have to switxh on the fan yourself whenever you need it.
Jun 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Sunpentown 11 in. SR-1330 Electric Cooktop Logo
Top Sunpentown Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Sunpentown Cooktop Expert? Answer questions, earn points and help others
