Question about Hobart A200 Stand Mixer
How do I access gears in a200 hobart. I don't see any screws to detach top. top looks painted shut.
    Scholar:
  • 44 Answers
There are two screws holding an access cover on the top front half of the mixer. These screws are normally plainly visible - has it been repainted heavily enough to hide the screws?
If you can't see the screws, all I can say is they are there, under the paint. Maybe shine a flashlight accross the top front half at an angle and look for a hint of a slotted screw head in the paint.
I'm not sure what the access cover is made of nor am I certain if the screws are stainless steel, but if the cover is aluminum and the screws aren't stainless steel, then a magnet should be able to locate the screws for you.
The screws a usually a domed-flathead screw, so some very close inspection of the paint surface may show a slight "bump" where the srews are.
Posted on Nov 25, 2010
How to invert motor turning direction?
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
How to change hobart a200 motor bearings
Do not heat up you have to strip the gear box but not all take the top gears off but look what you are doing its got to go back the same way or it won't work you have to take the worm gear off and then you can take it out from the back but if you can't do it get in touch with **** at x bakery in Haywood and ill sort it for you hope this helps it is a big job sorry
Jan 06, 2013 | Hobart A200 Stand Mixer
I've a hobart a200 that i want to recondition. How to remove the motor inspection cover. There 's a bearing with a nut, how to remove the nut, the rotorshaft keeps turning.
First, remove the steel ring sitting recessed into the hole where the nuts are.
Remove the top transmission cover (top front of mixer, two screws) allowing access to the motor's cooling fan blade.
Using a small prybar (or large, if you wish), prevent rotation of the rotor by placing the prybar on one fin of the fan blade, and bracing it against the mixer's frame. Remove nuts with a 3/4" socket and ratchet.
Aug 08, 2010 | Hobart A200 Stand Mixer
Trying to adjust gears on a A200 Hobart Mixer can anyone help?
only adjust ment is top nut tight on center shaft and botton two nuts finger tight then locked against each other. if shifting issue is still a problem you have something inside bad or wrong.
Apr 16, 2010 | Hobart A200 Stand Mixer
Looking 4 used parts A200
The safety cage kit is not cheap and you may not find a used cage. Why would you want to install used gears? They would have been removed from a mixer that has failed for some reason. Usually broken gears or shafts.
Mar 06, 2009 | Hobart A200 Stand Mixer
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
May 05, 2008 | Hobart A200 Stand Mixer
? Hobart A200 Mincer/Mixer wont work
What kind of bang was it ? an electrical or mechanical. The A-200 has a stator and rotor assy with a start capacitor and relay behind the back cover at the head of the unit. You can access the retaining nut for the rotor (motor) shaft by removing the small 2 inch cover and getting a wrench on the nut and spinning it by hand. The handle you mentioned with the three numbered selections are your speed settings and everything is driven through a planetary drive. Hobart A-200 have been around longer than I have (im 48) and are work horses and in my opinion, are the top of the line for mixers. Put it this way, I would take a 25 year old A-200 over a brand new Varimixer or other brand name. You can access parts manuals and break downs on Hobarts web site with model # and M/L # any other question e-mail me capt_rick1912@yahoo.com if you cant find what you are looking for I will e-mail you a wiring diagram (found behind the small gear selection cover on side) Good Luck......Rick
Apr 06, 2008 | Hobart A200 Stand Mixer
Servicing Hobart A-200
these mixers dont use oil,they use grease.you will have to open the transmission to change the grease.any ? let me know im a hobart tech.
Jan 25, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
117 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
