HOW CAN I SET UP MY EAX, PRINTER WITHOUT A DISC I HAVE A ARRIS MODEM
    Guru:
  • 1,463 Answers
Hi
whats the full model /make of the printer i will check for the drivers ,aslo which windows o/s you running .
riz.
Posted on Jun 18, 2008
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
Can't Connect TV to Wifi
You have to go to network setting on tv and printer and find something that says ip and set it to automatic
Dec 02, 2013 | Arris Computers & Internet
I just got a surfboard sbg901 couldn't lind it listed. My computer refuses to take the startup disc. Says it has a trojan and shuts down. I hooked the modem up an dit works fine. I cannot go wireless...
If you are booting from your OS disc, there will be no system loaded and certainly no anti virus loaded so it is not likely it is loading from the start up disc. Ensure the BIOS is set to boot from your start up disc first.
Oct 13, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Cannot connect router to arris modem
You will have to unplug your computer from the modem to plug in your router. Then you will have to plug the two computers into the other ports on the router. If this doesn't help. send more information on how you have it set up now, type of router and type of computers (desktop or Laptop, Wired or Wireless).
Jun 02, 2009 | Arris Touchstone 450a (CM450) Modem
Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance.  I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
  1. In my case, I needed to set the AirPort to DHCP in the AirPort Utility application.
  2. Power down the AirPort Extreme
  3. Power down the Arris. You achieve this by unplugging the Arris *and* removing the back-up battery.
  4. Wait a few moments.
  5. Insert the battery into the Arris.
  6. Plug in the Arris power supply.
  7. Wait for the Arris to go through the restart protocol; when all the lights on the front panel are solid green, the start-up is complete.
  8. Power up the AirPort Extreme; wait for the front panel light to go solid green.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online.  While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what.  I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
Mar 17, 2009 | Arris Touchstone 450a (CM450) Modem
Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Dec 29, 2008 | Arris Touchstone 450a (CM450) Modem
How is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Jul 22, 2008 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
