Question about BroilKing Grilling
Broil king signet 90 9867-87 igniter quit working battery has been replaced
2 Suggested Answers
  • 4736 Answers
SOURCE: Can you send me instructions to install and
Ruby, here's a link to the entire assembly manual for your grill and 3 other Broil King Models. They all assemble the same way. You may have to remove the front control panel to remove the old one and install the new one.
http://www.broilkingbbq.com/2010/manuals/10084-E41_Rev_E_1209.pdf
Hope this helps you. Please let me know. Thanks.
Posted on Jun 10, 2011
2004 Harley Davidson FLHR - FLHRI Road King quit running
Hi, Willie and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Road King quit running while riding
Harley Davidson Touring Workshop Service Repair Manual 2004
$10 very cheap includes electrical diagnostic manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Sep 04, 2017 | 2004 Harley Davidson FLHR - FLHRI Road...
Igniter broil not work.
there must be a broken wire or a bad connecton, trace the wire
Jan 27, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignition button- no response
Unscrew the ignitor cap there should be a double A battery there, if not you can get ignitors at any barbeque store, Ace hardware etc.
Feb 22, 2012 | Crown Verity Broil King 40 Propane Grill
I have a Broil King soverign XL that I purchased at Sears 3 years ago. The front of the actual barbq that holds the grills has expanded ourward. The grills are to short now. What happened for the case to...
Jim, that's an extremely unusual occurrence. As the fire box or tub is made of cast aluminum. In my 15 or so years in the hearth and gas grill business, I have never heard of a case like this before.
I suggest that you contact Onward Manufacturing, the maker of Broil King Grill for their take on this.
Customer Service can be reached at 1-800-265-2150.
Thanks for choosing FixYa.
Sep 14, 2011 | Royal Sovereign Broil King Sovereign 90
Natural gas Bril King BBQ . Want to convert to Propane.
Unfortunately, there are no gas conversion kits available for any Broil King Grills. That's why they always make a Propane Model and a Natural Gas Model. In fact, Onward Manufacturing Co, the manufacturer of Broil King, don't recommend that conversions be attempted.
I'm sorry, I wish I had better news for you,
Jul 21, 2011 | Crown Verity Broil King 20 Propane Grill
I need a new burner for my Broilking 531/33GBC and the grid the coals rest on. Pity all the new BQs are all just tin.
Onward Manufacturing, the company who makes Broil King grills, doesn't make a gas grill that uses coals above the burners. I have been a Broil King Dealer since 2005, I haven't seen one yet. Are you certain you have a "Broil King Grill?" As the Model Number 531/33GBC, you listed, doesn't show up in my data base for Broil King. Perhaps you have a Broilmate grill? Which is made by a different company.
Please advise. Thanks
Jun 26, 2011 | Grilling
Can you send me instructions to install and replace the electronic ignitor on my Broil King Signet 70 bbq Tks I have the new part...
Jun 10, 2011 | Grilling
Im looking for a side burner handle for a broil king soverign xl
BroilKing, for whatever reason, doesn't sell parts directly to the consumer. They would like for you to return to the dealer you purchased it from, for parts. However, there is another company that stocks hundreds of parts for juts abut all makes and model grills. In fact, I've purchased parts from them, successfully. Appliance Factory Parts should be able to help you.
http://www.appliancefactoryparts.com/gasgrillparts/brands/broil-king/broil-king-handles.html
Happy Grilling!!
May 24, 2011 | BroilKing Sovereign XL (LP) Grill
Just got the bbq yesterday - the 2 burners on the left ignite and burn normally. The third burner on the right won't ignite either manually or with igniter...you can hardly hear the gas coming out.
It may be a case, that the burner orifice for that burner is clogged with shipping debris or something similar. Remove the third burner and inspect the orifice for foreign debris. Also, check the venturi valve on the end of the burner for clogs. Onward Manufacturing, the company that makes Broil King grills is a good company and stands by their product. If you continue to have a problem with the grill contact their Customer Support Hot-line 800-265-2150.
Hope this helps you to troubleshoot and solve the problem. Please let me know and Happy Grilling
May 23, 2011 | BroilKing Signet 20 Gas Grill
Bake burner
It is almost always a weak bake igniter. These age and will no longer pull enough current through them to allow gas valve to open. If bake igniter comes on and doesn't light, replace it.
Nov 17, 2007 | Ovens
Grilling Logo
112 people viewed this question
Top BroilKing Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a BroilKing Grilling Expert? Answer questions, earn points and help others
