Question about Kenmore 64802 Top Freezer Refrigerator
GE refrigerator Model TBX18SASGLAD freezer keeps frosting up and then refrigerator section gets warm. Defrost freezer and refrigerator works fien for one week or so before freezer frosting up again.
  • Kenmore Master
  • 43,501 Answers
The defrosting of the freezer is control by either a defrost timer or the main control board... or you unit I think it is the control board....
The heater is an electric element on some and an infra red bulb on others...
So, you could have a bad heater or a bad control board....the best thing to do is catch it in defrost mode and then check for voltage at the heater...or if you are comfortable with electric just jumper the heater and see if it works....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 14, 2010
My Model #gts22wcp fridge stopped getting cold. freeezer works great. Only blows cold air into fridge if freezer door is open.
Possibly a problem with the defrost system. If the cooling coils behind the freezer wall start to build up too much frost or snow, the air flow to the refrigerator section gets blocked first. So the freezer still works but the fresh food section starts to get warm . As the frost continues to build up, in time the freezer section will only get as cold as the fresh food section should. There are 3 main parts to the defrost system. You could have a burned out defrost heater, a bad defrost timer, or a bad defrost termination thermostat. The heater is located directly under the cooling coils in the freezer. The termination thermostat is a silver round disk clipped to the top of the same cooling coils, and the timer in located in the control panel in the fresh food section.
Apr 02, 2016 | GE Refrigerators
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer frosts up and fridge becomes warm
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Also check the bellow link:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 04, 2011 | GE GSH22JFT Side by Side Refrigerator
No ice from icemaker, rest is 'warming up' freezer fan goes on
OK I need to ask you a few questions about your refrigerator. You mentioned that both sections are warm does this mean not cooling at all as if warm like room temperatures or do you mean not cooling enough to make ice or keep food at safe temperatures like 38 degrees f.? please answer theses questions because this will tell me a lot. If you look into the rear of freezer do you see snow or frost building on the rear wall of freezer? If yes then unplug and begin manually defrosting and placing frozen goods into a standby refrigerator. We will need to decide if there is a defrost problem, compressor start problem or a motherboard problem. Could you do that and answer these questions ASAP so we can get you going or decide what direction you will need to take. Thanks, Sea Breeze
Mar 29, 2010 | GE Refrigerators
Freezer working refrigerator not getting cold
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Jan 05, 2010 | GE Refrigerators
Fridge warm
The frost build up is blocking the flow of cooling air from reaching the refrigerator section. If you take the cover off the frosted area and melt the frost off with a hair blower your refrigerator will work fine for a few days to a couple weeks, and then the problem will show up again. You need to determine why it is not defrosting by itself. You do not list the model number or even an aproximate age of your unit, so I can not be very specific with a solution. Test the defrost heater and then look at the defrost control timer. Also, look for any signs of air leakage into the refrigerator, such as a poor gasket (look at the bottom of the fresh foods gasket in particular) or a dispenser area if your model has a through the door ice dispenser.
Jun 21, 2009 | Refrigerators
GE Model TFX25KRCGWW there is frost in the freezer and it appears the temperature in the freezer and refrigerator is not cold.
Just went throught he same thing. The evaporator coils ( the ones in the freezer section) have defrost heaters that cycle occasionally to keep them frost free and they are not working. It could be the defrost thermostat, defrost timer, or the heater elements. The timer is the first thing to check followed by the thermostat and then the heater elements. Advice, help, and parts are available along with detailed diagrams of the refrigerators at several web sites:
http://www.appliancepartspros.com/partsearch/
http://www.repairclinic.com/Home.aspx
http://www.pcappliancerepair.com/
http://www.partselect.com/default.aspx
Apr 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
