System keeps restarting will not load safe mode or boot in it blue screen error codes are 0x0000007E/0x0000005/0x82CC2963/0F89E78AC/0xF89E75A8
  • Frankie Pink
    Frankie Pink Nov 18, 2010
    yes I will replace the hard drive and install windows seven 64 bit thanks
  • 11,800 Answers
Something is wrong at hardware level - either the BIOS is corrupted or some of its settings are incompatible with windows or its basic drivers.
Try to boot in the BIOS and in there set everything to default then change the boot order - put the cd first. Now boot from a Linux Live-CD - if it boots just fine and all hardware is correctly recognized and accessible then windows is to blame - reinstall it.
Posted on Nov 14, 2010
My laptop boots halfway even in the safe mode and blue screen appears and restart the computer. what to do
Hi may I know what operating system you have on your laptop? If may be due to RAM or maybe with RAID or BIOS. Reinstall your operating system it will fix your bluescreen error.
Jul 13, 2015 | Computers & Internet
The Blue screen of DEATH, code error STOP: 0x0000007E
try to open ur windows through safe mode
steps: switch on ur comp an press F8 key continually Select safe mode through UP and DOWN keys Press enter on Safe mode, it will start ur windows through safe mode. you'll not able to hear ur sound , ur internet etc.etc. If it is working properly then restart ur windows . ( If the problem is same then try following steps)
there r two solution's:
(1) It's might be there is some issue with ur RAM. Remove ur RAM n gently clean it with pencil eresar. Then reinstall it.
(2) Might be windows is corrupted that's why it shows blue screen before startup. Take ur data backup and reinstall ur OS.
May 31, 2011 | Computers & Internet
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
How do i fix the blue screen stop 0x0000007e on my dell laptop vostro 1510. I can't even start in safe mode.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Feb 10, 2010 | Dell Vostro 1510 Laptop
Having a blue screen issue, boots to windows splash screen, then gives blue stop:0x0000007E error with various (0xc0000005,etc) variations after it. have tried to boot with a floppy, no go. will not let me...
Have you tried to boot in Safe mode? Well if not then press F8 as the PC starts and select safe mode. If it works, then select the 'system restore' option which will appear and restore the system to as far back as it worked very well. Your files will be intact. Well if safe mode those not work, then since you cannot change your boot order to boot from CD/DVD, then you would have to take out your hard drive and connect it to another PC and follow this tip of mine: http://www.fixya.com/support/r3766678-booting_bootable_windows_cd_dvd_fresh
All the best.
Jan 14, 2010 | Panasonic Toughbook 29 Touch (P/N...
Blue screen error vista with the message of : ***Stop: 0x0000007E(0X0000005,0X8E8E88D9, 0X83E046F8,0x83E043F4)
hi
use safe Mode to recover the problem
1:restart the computer
2:Press and Hold F8 Key
3:Select last known good configuration> and press enter
(if the above solution did not solve your problem use the second method )
4:instead of selecting last known good configuration you select Safe mode and do System Restore
Dec 26, 2009 | Microsoft Windows? Vista Home Basic...
Error code 53000:031e stop:0x0000007E COMPUTER WIIL NOT BOOT UP
hi there !
-boot to SAFE MODE
-restart the computer and press F8 and choose SAFE MODE then do the steps below
Windows Update Causing STOP Error 0x0000007E
-For now simple system restore should fix the issue, else uninstall this update by booting to safe mode.
-Uninstalling windows update KB973879 and hiding this update from available update is currently seem to be fixing the issue.
In case if removing update KB973879 doesn’t fix the issue, we need to remove remaining two updates KB970653 and KB972036.
cheers!
Oct 20, 2009 | Dell Latitude D510 Notebook
I am having a acer laptop, while i was rebooting my system suddenly i got the blue screen with below error STOP: 0x0000007E (0xC0000005, 0x80536268, 0xBA4CF3B8, 0xBA4CF0B4)...I cant even boot with the safe...
This might help you.
Otherwise I need more information:
When did it start - after install, after update, after changing some components or something else? Does the message state in which driver did the error occur?
Oct 14, 2009 | Microsoft Windows XP Professional
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
