Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I have a Hot Water Heater Model #GE40M06AAG. We have had it a little over a year and a couple of times a week we run out of hot water. We arent over using it. The breaker hasnt tripped. We hit the reset button and sometimes that works and we get more hot water. It is an intermitant problem. Any suggestions??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Bad reset mechanism.
Posted on Jan 16, 2014
5 Suggested Answers
SOURCE: I have a GE hot water heater, SE40M12AA01, dual
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 26, 2011
  • 122 Answers
SOURCE: installed new rheem 40 gal
did you turn the power on BEFORE you filled it with water???
this is a pretty common mistake. you will need to check the upper element to make sure its working.
most water heaters have an upper and lower themostat. the upper thermostat is the one we need to check.
use your volt meter...
turn the power off, test with your volt meter to make sure! remove one wire from the element, not the thermostat, and check resistance on the element. if no resistance, you burned the element, and will need to replace it.
replace with same wattage, usually 4500watts. it will be written on the element.
also, I like to push the reset button on the thermostat to make sure it wasn't tripped.
Posted on Aug 31, 2010
  • 408 Answers
SOURCE: THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Posted on Mar 04, 2009
  • 35 Answers
SOURCE: My hot water will not get hot at all. Model
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Posted on Feb 23, 2010
Our water heater is having issues. A couple months back it stopped giving hot water, so I looked up some simple DIY stuff, and found out about a red switch that resets it.
Hello, Aaron -
It is time to contact an authorized repair person for your make of water heater and repair the electrical fault with your water heater. Depending upon the age of your water heater, it may be time to purchase a new one.
According to the well-respected U.S. publication, Consumer Reports, which evaluates all kinds of products, the average life expectancy water heaters are:
- electric water heater: 11 years,
- gas water heater: 10 years
- tankless water heater: 20+ years
Source:
https://www.consumerreports.org/cro/news/2009/03/by-the-numbers-how-long-will-your-appliances-last-it-depends/index.htm
Best wishes.
Apr 19, 2018 | Water Heaters
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
I purchased a GE 40gallon water heater model: GE40M06AAG. What type of circuit breaker do I need and it says that its a 240/208 volts AC only. Can I use it and what do I need if I can use it?
You need a 2pole 30 amp breaker that will fit what ever style breaker panel you have....then you will need to run 10/2WG wire from the breaker to the hot water heater...
heatman101
Aug 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Oct 11, 2009 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Very little hot water
if your heater is near the ten year mark, thats signs of going bad.....
Apr 29, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
3,116 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
