Question about Ovens
HOW TO REPLACE THERMOCOUPLE IN TOP OVEN OF AGA COMPANION STOVE. have removed side panel but find the cable disappears behind the aga proper, and how one accesses it is a mystery. Can you help? Bridget Goldsmith
watugot
  • 290 Answers
SOURCE: Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Posted on Dec 03, 2007
  • 13 Answers
SOURCE: Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Posted on Nov 02, 2008
tborn6
  • 700 Answers
SOURCE: Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Posted on Jan 11, 2009
rmrcompany
  • 3 Answers
SOURCE: The door on my Okeefe and Merritt antique stove
O'Keefe and Merritt is always a challenge to the inexperienced because, although two stoves of the same year and model can look identical, there are subtle differences in both, especially in the door spring mechanism, that make it difficult to explain without seeing the stove and/or asking you a series of questions in person. Here it goes anyway: Some models have access panels that are visible when you pull out the broiler drawer. This makes changing a spring a breeze, as long as you know which spring you need. A sample of a broken one, or and intact one always helps when buying a replacement. Other models operate on a system of hooks, cables and springs. These often require a skilled technician to come out and repar for you. Most of the time, the door has to be physically removed from the frame so that new cables (and sometimes rods) can be installed on the hinge and then the door would have to be re-installed fishing the cables through a small opening on the bottom of the stove. A spring then attaches to the cable and the hook of the spring is then attached to one of three small aligned holes on the bottom stove panel.
One constant i s that there are 2 sets of springs for each of the door panels. You are right, there are springs in the middle. And you are also right that the white panel removes from the door after you remove the truss head sheet metal screws.
You might want to give me a call and chat about this further at RMR Company, Inc (RMR Stove Company) 619-231-2808
Posted on Dec 11, 2009
  • 715 Answers
SOURCE: oven overheating in aga d c 6 model
replace thermostat
Posted on Feb 07, 2010
AGA electric oven will not heat up and Gill will not work even though orange light is on
The electronic igniter is not drawing the proper amperage to open the grill gas valve...
Jun 28, 2016 | Ovens
Thanks/Mike
Dec 02, 2007 | Ovens
I am looking to get an aga cooker instaled gas with my own corgi reg fitter and need assembly instructions
Installation really isn't something that can be done from a set of instructions - it's more complicated than that and needs an AGA trained engineer to do it. Suggest contacting AGA Service for advice, as a badly installed AGA may not function correctly.
Sep 18, 2010 | Ovens
Is replacing a thermocouple in an oven difficult? my oven has started cutting out after just a minute or two of being on. On closer inspection, i've noticed the wire seems to be corroded at the base of...
My Kenmore electric wall oven will not increase the heat to the desired setting. The electronic display holds at 100 degrees. Could the problem be the thermocouple or the electronic range control. The range control is hard to find, which is part # 318010701, made by Fridgidaire.
Jan 17, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
My old oil-fired Aga has started sooting up and the temperature falls within a month. My oil supplier says a c onstituent has been removed from the oil when it is refined and has given me an addative which...
sooting is an indication of incorrect air/fuel ratio
too much fuel and not enough air
as the fuel has changed in quality so the jet sizing may need reducing or the blower fan needs to go faster
get in a boiler professional or change the fuel brand and supplier
Nov 17, 2017 | Gaggenau EB290 Electric Single Oven
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Ovens Logo
191 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
