Question about ViewSonic VX2235wm LCD Monitor
How to open a viewsonic vx2235wm monitor? - ViewSonic VX2235wm LCD Monitor
  • 11,361 Answers
See my pictures of failed VX series. Use thin flat blade screw driver to crack it open at the bottom egde of the monitor.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 14, 2010
  • Randall Ayerst Jun 29, 2011
    Please refer to the FixYa problem solution "White Screen When Power On". This solution gives access to the site www.ccl-la.com. via these words underlined in blue. When at this site click on " Viewsonic" under the list of monitor manufactures given on the right hand side of the page. This will lead you to a full discription of how to disassemble the monitor. Read the comments section as well since my monitor had a different power board as compared to the one discribed in the photos. I give a discription on my board and the capacitors that failed.
NetSalem
  • 55 Answers
SOURCE: cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Posted on Jun 04, 2008
SOURCE: Monitor resolution
I ran this monitor for ages on a gforce 7800gt graphics card with flight sim and had no problems until one day it did exactly the same thing.
After uninstalling and re-installing Drivers for both screen and graphics card failed I searched the forums and it is not the monitors fault, its the graphics card not understanding the monitor. The card reacts to any changes you have made to it and adapts to suit (Eg; LCD screens, TV's, S.Video cables etc)
With the Monitor you get a DVI cable. Switch off the computer, unplug your VGA cable and plug in the DVI cable then switch the computer back on.
When the computer reboots to the main screen go into the NVIDIA menu and select single screen view (disable all clones with TV's)
Now in the resolution choices in the NVIDIA menu the resolutions will have changed to max 1680x1050.
Hope this helps.
Posted on Feb 10, 2009
BoiseLCD
  • 63 Answers
SOURCE: Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Posted on Apr 03, 2009
  • 1684 Answers
SOURCE: where can I get a schematic so I can replace
We just posted the repair guide for this unit on our web site at:
www.ccl-la.com The repair involves changing 8 capacitors. On our site look on the monitor repair page 2 and then it is listed 3rd guide down, same as Westinghouse LCM-22W3. The power supply is DAC-19M009
If you have any questions just let us know at: tech@ccl-la.com
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
  • 1684 Answers
SOURCE: hello viewsonic vx2235wm no power
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
Our viewsonic monitor is VX2235WM-3 the
The short answer is no, becuase by time you pay the $50 for the backlight, and $75/hour for the tech to fix it, you can buy another 22inch for the same price and have a 5 year warrinty.
Sorry,
Have a nice day
Aug 29, 2011 | ViewSonic VX2235WM Monitor
Monitor turns on then turns off
The most common cause of power issues with this unit are capacitors on the power supply board. This is an easy repair. Here is a link to a repair guide with full instructions showing how to open the monitor and what to look for and replace to rebuild the power supply board and revive the monitor.
I hope this helps.
Dec 27, 2010 | ViewSonic VX2235wm LCD Monitor
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
My viewsonic vx2235wm monitor keeps going black and then after a few seconds shows the picture again.. what the heck is wrong??!!
It could be a power-inverter board problem.
These 22s tend to have bulb issues too.
It would have to be opened up to check for possible obvious problems on the power board first.
If you can open it and get me a picture or two of the board to bammbamm@ptd.net, I might be able to see if any obvious troubles are showing.
Aug 18, 2010 | ViewSonic VX2235wm LCD Monitor
Instructions on how to disassemble and fix a Viewsonic VX2235WM
Here is a link to a repair guide that shows how to dis-assembly the unit and that what to look for any replace on the power supply board to repair most problems on the VX2235wm monitors. The repair guide has pictures and videos showing the procedures.
BuddyMc
May 19, 2010 | ViewSonic VX2235WM Monitor
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
I need sofware of my viewsonic
The links below are two picture of the CD came together with the viewsonic monitor.
http://i590.photobucket.com/albums/ss341/VHC08/VX2235CameraAssistantSoftware.jpg
http://s590.photobucket.com/albums/ss341/VHC08/?action=view&current=VX2235Driver.jpg
If you happen need the driver only viewsonic.com has it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.viewsonic.com/products/archive/vx2235wm.htm
X2235wm User Guide, English PDF: 513KB
The CD contain Camera Assistant Software is only 18M, which is an executable file. The software is not too impressed to me. The other CD is the driver disc. It also has a pdf owner's manual and the Adobe reader 4.0
View More Drivers/Utilities »
Jun 03, 2009 | ViewSonic VX2235WM Monitor
Monitor will not turn on.
You might look at this link:
http://www.fixya.com/support/t797776-viewsonic_vp930b_3
It might be that some caps need replacing.
Feb 27, 2009 | ViewSonic VX2235WM Monitor
ViewSonic VX2235wm LCD Monitor Logo
720 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
