Question about Roper Kitchen Ranges
Oven displays f-3 code than beeps and shuts off email is apatsfan @aol.com thanks
    Top Expert:
  • Roper Master
  • 9,472 Answers
F3= sensor circuit, could be the sensor, wiring harness or the clock, check the harness first from the clock to the sensor.
Posted on Nov 14, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Top Oven displays F2 code. Beeps constantly, even after shutting off power and restarting. Need it to work by Xmas!! I have old control panel that still worked, but was extremely dim. Will this fix my...
Looks like you have the key stuck code. To replace the panel, first shut off the power, then take the screw out that are holding the oven into the cabinets. After that you will need to pull it out from the cabinets about 4 inches. Then take off the screws holding the control panel in place. Here is an exploded view of the control panel, this should help. Just use the link here: http://www.partlinx.com/search/SearchImageViewer.asp?cImageURL=http%3A//www.partlinx.com/images/00308/i620620.GIF
Please rate my solution if it was helpful.
Thanks, Repairman45
Dec 19, 2010 | Jenn-Air JJW9627DDW Electric Double Oven
I have a GE Range. Purchased in 1993. The user guide says it is for JSP26GP, JSP28GP, JSP31GP. The thing won't quit beeping and the function code displayed if F1. What should I do? Thanks!
The F1 error code means your oven temperature has exceeded 590 degrees and the beeping is to warn you to shut it off.
Itis likely that the oven thermostat has failed, so you will need to get it replaced.
Jan 04, 2010 | GE Ovens
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error light
Hi thanks for the question. the f 3 code says the oven sensor is open. that's the part located in the oven. top left in oven .cut the power to stove . replace the oven sensor thanks the appliance doc
Sep 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Abit SG-80 Rev 1.0 Motherboard beep codes
type in beep codes into search engine find the ones for your M/board it usually means you have a fault on it try changing video card or ram
Jul 30, 2008 | Mercury P4VM800M7 Motherboard
Kitchen Ranges Logo
78 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
