I have the Sharper Image 51334Si slide/negative converter. The scanner/converter overscans my slides and overexposes them. I have re-started and re-calibrated the unit twice. The sldes are from the 1960's, but they are in perfect condition, no dust, scratches or damage of any kind. Do you have any suggestions for me to help this problem?
jackboy
  • 2985 Answers
SOURCE: Pacific Image 1800u scanner and XP pro compatiability problems ?
If it is loaded and running then that side is OK. It seems to be a firmware breakdown in the scanner. Checkout the makers website
Posted on Aug 02, 2007
SOURCE: sharper image desktop slide viewer SM425
I don't know if it's the same unit I have, but if it is, when you pull out the bottom of the screen for viewing then the knob will pull out.
Posted on Dec 31, 2007
SOURCE: scan colour slides
Hunted in the back of the wardrobe and found the original software. Val
Posted on Oct 15, 2008
SOURCE: i need the drivers for the hammacher schlemmer
i am not sure but you might look at vupointsolutions.com downloads for FS-C1-VP
i thin 64 bit not thre tho
Posted on Nov 11, 2009
SOURCE: My Mom purchased a Jobar's slide & negative scanner by RX Optics
install for scanner for umax astra 2500 for windows 7
Posted on Mar 29, 2010
Is there a driver for Mac OSX (10.11.3)
The manufacture would be the primary source if a driver does exist.
Apr 04, 2016 | Jobar RX Optics 35 MM Negative and Slide...
Edge Of Scan Overexposed
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Oct 05, 2008 | Nikon CoolScan V ED Film Scanner
Installed the JB5323 Jobar Slide & Negative Scanner into a Window's 7 Professional contained in my Dell and it will not give me all the different things it has. It won't convert the negative...
You don't need any special software or hardware to do this, and it's really easy too! Open one of the saved image files of the negative scan using Microsoft Paint. It's under Start -> Accessories.
Now click select in at the top, and then right click anywhere on the image. At the very bottom of the menu, there should be an 'invert colors' option. Click it. Your negative should now be a normal picture =).
Sep 10, 2011 | VuPoint FSC1VP
My Epson 4180 does not recognize the correct size of slides and B&W negatives even though I am using the carriers that came with the scanner. For example, the first scanned image on the negative strip...
I had this problem and what I figured out is that there is random stray light getting through between the holder and the slide itself. So, I created another template and taped it to the holder. The goal is to eliminate the stray light. This is how I did it basically. Get a black sheet of construction paper. Line it up with the Epson slide template and cut out holes for each slide so just the image/film plus a tiny edge around is exposed.
Feb 12, 2011 | Epson Perfection 4180 Photo Flatbed...
Can HP psc 1410 PRINTER SCAN NEGATIVE AND SLIDES
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
Black and white photos from many years ago now have a blue-green hue on them when they are scanned. it started after I scanned old slides.
Did you make changes to the scan type when you scanned the slides? It sounds like you have the scanner set to do a negative image as a slide would need.
Check the preferences for the scan type.
The scanning manual is available on Canon's Website.
Mar 17, 2010 | Canon CanoScan 4200F Flatbed Scanner
Just installed a VuPoint Solutions Fs-C1-Vp Converter. When a slide or negative is inserted, a black screen shows up on the ''live view'' screen. When we transfer, a totally black image is saved on the...
how do you put a SD card into the vupoint slide converter
it has a white plastic thing preventing the SD card from going in and i cant pull it out
Jun 15, 2009 | Office Equipment & Supplies
Require driver for Ion Slides 2 PC ... using Vista 64 bit.
MY ION SLIDES 2 PC WORKED WELL WHEN I HAD VISTA BUT SINCE CHANGING TO WINDOWS 7 IT WILL NOT WORK WHEN CLICK ON AQUIRE I GET THE MESSAGE CANNOT FIND THE SCANNER. PLEASE CONNECT 35MM FILM SCANNER. I HAVE UNINSTALLED THE PROGRAMME AND REINSTALLED IT BUT SSTILL GET THE SAME.
Feb 22, 2009 | Office Equipment & Supplies
Distorted Scans
it could be your not scanner in a high enough resolution. I believe negatives have a 1000 dpi.
Oct 31, 2007 | Epson Perfection 4180 Photo Flatbed...
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
