Question about Burton Audex Pi Mp3 Mens Xl Pimp Snowboard Jacket
I hav a Burton Audex link jacket. I have a problem with the audex system. The control panel automatically switch to discoverable after aprox 10 seconds of turning it on then won't access the menus again. Also, it won't pair with any device or recognise my iPod when I plug it in. Any advice would be great. Thanks.
Id check the cables, they may be damaged, try it with the jacket flat on the floor. ive gone through 4 jackets all with bad wiring, unfortunately Burton doesn't have any more warranty replacement jackets...
Posted on Nov 23, 2010
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
Jun 08, 2015 | 1997 Ford Taurus
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
Premature low battery signal & then turns off system where can I get a replacement battery P/N 0171971b01
I have 2 new batteries with charger for you. Price 100 US$. The batteries are new and never used.skype: pimvanloosbroek. Can show you the batteries on skype.
Dec 30, 2010 | Burton Audex Motorola Cargo Jacket Men's...
I'm trying to replace a button on my Burton jacket
Needle and thread should do it. If you are looking for the actual button, you wont. These things are made in China a year in advance. Best bet would be to find a nice button at a fabric store and use that instead.
Jan 01, 2010 | Burton Tango Snowboard Jacket 2009
I need a replacement zipper for a last years Burton System Jacket. Where would I find one?
Call your local large camping store and ask them who does all their tent and pack repairs. Then call those people and talk to them about Zips
Nov 09, 2009 | Burton System snowboard Jacket
Burton Audex Pi Mp3 Mens Xl Pimp Snowboard Jacket Logo
296 people viewed this question
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
