Question about Kodak Easyshare C813 Digital Camera
I put brand new double AA batteries into my camera and it still is not turning on , how do i get the camera to work?
  • Kodak Master
  • 4,738 Answers
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Nov 14, 2010
Error signal
You should have two types of batteries.
2 CR123A batteries: (lithium)
4 AA batteries (alkaline or nickel-metal hydride)
Never use Nicad batteries. Never use different batteries together. that is for the four AA batteries. They should be the same brand and the same capacity.
The lithium batteries should be the same brand and same date.
Before changing batteries, always switch off the camera.
When you use rechargeable batteries, be sure you did charge them fully, before putting them in the camera.
Oct 28, 2013 | Fuji FinePix S2 Pro Digital Camera
My camera won't turn on. I put in brand new batteries straight out of the package and i put them in to the camera and it sttill won't work. i hold the power button for about 10 seconds. Not working.
AA batteries can be placed in the camera the wrong way around. They can also cause corrosion of the battery contacts if left in for long periods or run down. I would check these two things before assuming a fault.
Oct 25, 2010 | Vivitar ViviCam 3780 Digital Camera
I was wondering why I take a shot and it says empty battery when brand new ones are installed?
dear sir,
this is not a big problem,as for your camera model the battery recommended by olympus is (Battery AA (2) batteries (NiMH recommended)
the problem is,normal aa batteries and aa(nimh)batteries looks same by mere appearance........
kindly ask the shoppe for AA(NiMh) batteries and put in ur cam,it works for sure..........
thank you...take care............................
Oct 09, 2010 | Olympus FE-310 Digital Camera
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
I put new batteries in and the green light turns on but then it shuts off and deosnt turn back on
Often I have found with modern digital cameras of all brans is that generic batteries no longer have the power to made them run, so even brand new generic batteries will not start the camera.
the solution is you always must buy the expensive brands or invest in a rechargeahle battery system for AA batteries, which mine takes the best. So try that out. I think u will find that money does make a difference
Jan 16, 2010 | FUJIFILM Finepix A200 Digital Camera
Camera will not turn on,tried new batteries still nothing.camera is kodak c813
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
- oxy-alkaline digital camera batteries AA
- Ni-MH rechargeable digital camera batteries AA
- alkaline batteries AA
- lithium batteries AA
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the dial mode.]
7. Turn on the camera
if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 17, 2009 | Kodak Easyshare C813 Digital Camera
When i turn on my camera it will not extend or let me set the men
Check batery type suitble for your camera, also ensure correctly installed(+ -) Check contacts are clean
Sep 24, 2009 | Fuji FinePix A360 Digital Camera
Camera shuts itself immediately after starting it
Did you try using the coolpix batteries that came along with the camera? check the ratings on coolpix batteries and compare them to the batteries that you are using now.
Mar 23, 2009 | Nikon COOLPIX L10 Digital Camera
GE Digital A735 camera is not turning on
try looking at the symbols on the battery and then on the camera and try putting them in that way and if that doesnt work try an other brand of batteries
Dec 13, 2008 | General Electric A735 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
