Question about Kodak EASYSHARE M340 Digital Camera
Memory card causing camera to freeze & stall - Kodak EASYSHARE M340 Digital Camera
  • Kodak Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Nov 14, 2010
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
What does CHA mean
Nikon says this about CHA:
When a Memory card is inserted into a D-SLR camera, the camera checks the card for compatibility and usability. There are three possible results of the test:
1) Camera detects valid Memory card, displays number of remaining images in top LCD
2) Camera displays "FOR" in top control panel LCD. The camera has detected a valid disk partition map, but was unable to read the first sector of the Memory Card. Formatting the memory Card using the cameras format option, should resolve this condition and allow the Memory card to be used.
3) Camera displays "CHA" in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
(Nikon's list of "approved" memory cards can be found here.)
Please note that the default disk format used in Windows XP is FAT32 and if a card is formatted with this setting on an XP system, a D1 series camera will report "CHA". Reformat the card as "FAT" to use in the D1 series camera.
When the CHA error is shown, typically the camera will freeze and require that the battery be removed from the camera before it can take another picture. After that picture has been taken, the camera freezes up again for many owners.
Some owners have success removing and either re-seating or inserting a new memory card in the camera.
Some owners have success clearing the error by removing the lens and then reinstalling.
The key to these "fixes" is that they don't all work for everyone. You might need to return the camera to Nikon for repair. You can arrange for Nikon service here.
I hope this helps and good luck. Please rate this reply
. Thank you.
Apr 06, 2011 | Nikon D90 Digital Camera with 18-105mm...
I have a Fujifilm FinePix S1800 and after I take a few pictures the screen keeps freezing. I can't even turn the camera off or on during this time. The only way I have been able to fix the problem is to...
Replace the batteries and remove your memory card.
If the camera has some built-in memory test the camera without a memory card.
If not, install a different memory card.
If the new batteries and memory card are not the cause of the problem you need to have the camera serviced. Service information is at Fuji's website.
If this helps please vote for my solution.
Feb 15, 2011 | Cameras
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
Camera freezes up
Use a higher quality SD card. PNY or SanDisk usually works well with flash camcorders. Also make sure it's a HCSD card ( High Capacity ).
Apr 04, 2010 | Mitsuba DV9002 Flash Media Camcorder
Freezes when you press button to take picture
I suggest you please scan your camera memory card. I guess its virus infected.
Thanks & Waiting for your feedback.
Jan 30, 2010 | Fuji Finepix F50FD Digital Camera
The unit keeps freezing up
Take out memory stick from camera and check does it still freeze?
I think memory card in camera is causing problem.
Hope this info will help you.
Dec 08, 2009 | Sony MHS-CM1 HD AVC Camcorder
Nikon coolpix 4100
I've heard the camera "STALLS" when any sd card larger than 256 is installed, how big is your card?
Feb 21, 2008 | Nikon Coolpix 4100 Digital Camera
Can't transfer photos
I suggest you get a memory card reader for your PC or Mac, sometimes, the built-in card reader or USB mass storage function of your camera bugs out and causes your computer to freeze up, this is due to the driver probably messing up.
Having a separate card reader for your cameras memory card will be useful and fast when making backups of your photos, and seldom causes hang-ups. A memory card reader easily attaches to your USB or firewire port too...
Dec 09, 2007 | Pentax Optio S4 Digital Camera
Playback mode is stalling
This is due to problem with the memory card. Back up all taken pictures. format the memory card with PC or camera itself and restart the camera. check if there is a problem. if there is a problem, ensure that if is free from dust or humidity. There may be problem with camera software. Better is to take it to a camera hardware engineer.
Jul 24, 2007 | Samsung Digimax V700 Digital Camera
Kodak EASYSHARE M340 Digital Camera Logo
91 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
