Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire Dishwasher I have a frigidaire dishwasher that won't drain. it run through the entire cycle, the dishes are clean but the dishwasher is filled with the dirty water. I have unhooked the hose and let the water drain out that way but when i connect evrything back it still doesn't drain.
  • 84 Answers
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Posted on Jun 20, 2008
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher won't drain. runs through normal cycles, and then just stops still full of water on the bottom. I have taken it apart and can't see any obstructions.
is there a clog in the hose somewhere because when ours clogged it would not drain it just kept circulating water all over the clean dishes and it was gross
Jan 03, 2011 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher is not cleaning dishes
i would suspect spraying arms or water temp not working.adrian,,,
Jul 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Residual particles on dishes and glasses
Hi. Check to be sure you don't have water in the bottom of your machine after the cycle completes. If you do, then you have a partial blockage in your drain pump or your drain line or the trap under the sink. If there is no water, do this. Put two cups of white vinegar into the machine when it is empty and then run your hottest and longest cycle. This will clean the interior of the machine.
That said, please always rinse your dishes before using the machine and always run the hot tap water into the sink until it is nice and hot before starting up your machine. These steps will greatly improve the sanitation of your dishwasher. J.
Jul 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Hi, my Frigidaire dishwasher doesn't seem to clean
Factory Defect, where I was given full refund plus re-installation costs from Lowes...
Oct 04, 2009 | Frigidaire Dishwashers
I have a frigidaire dishwasher and it is not cleaning the dishes good. I ran it twice and there are still some dirty dishes mainly glasses. Also it doesn't look like alot of the dishwasher detergant is...
Have you ever used TANG DRINK to clean out you dishwasher. Empty a whole jar in washer and let run through the hottest cycle. This should clean all your jets
Aug 04, 2009 | Frigidaire 24 in. GLD2250RD Built-in...
Dish washer won't drain properly
either you have a blockage inside the drain hose at the attach point under the sink , or possibly somehting stuck in the drain pump itself, preventing proper drainage, the drain pump is acessible form underneath, usually mounted ti the right side of dishwasher, "unplug first HOT WIRES"
Jan 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
439 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
