Question about Garden
I have a ryobi ry30550 that only runs with the choke fully on.
  • chrismizel Nov 14, 2010
    I'll try the procedures and see how it goes. Thanks
    Top Expert:
  • Garden Master
  • 79,865 Answers
I have assembled a body of information about small engine fuel problems like you have, please follow the suggestions below and if necessary you will need to get a kit and rebuild the carburetor, a web site link to the maker of the Ryobi carburetor is provide at the very bottom.
Remove the fuel tank lines from the fuel tank and then unbolt and remove the entire fuel tank from the equipment. When disconnecting the lines, inspect them for any cuts or cracks and also look for any which have collapsed. As the polyvinyl plastic which comprises most of these fuel lines ages it has a tendency to lose its support, causing it to collapse, the fuel supply to the carburetor becoming restricted.
  • 2 Remove the fuel filter from the hose on the bottom of the tank and inspect it to determine if it becoming too soiled. If the filter has restricted air flow through it, or appears dark-colored with debris clinging to it's exterior, install a new fuel filter and discard the spent one.
  • 3 Empty any remaining contents from the fuel tank and spray carburetor cleaner into the tank for about 10 to 15 seconds, shake the tank vigorously for about a minute permitting the cleaner to dissolve any sediment from the bottom of the tank, then drain.
  • 4 Before installing the assembly back onto the device, remove the carburetor end cap and spray two or three short bursts of carburetor cleaner into the carburetor. Inspect to ensure none of the other carburetor mounting screws are loose. If so, tighten them and then reassemble the cover and reinstall the tank, connecting all fuel lines as you go.
  • 5 Add no more than one ounce of Seafoam fuel treatment into the fuel tank and then fill with your standard two-stroke fuel mixture. Proceed to operate the equipment to determine if the maintenance has solved the erratic behavior of the machine. If you still have difficulty, please refer to the information below.
  • Ryobi-Specific Protocol
  • 1 The Ryobi line of small power equipment has traditionally used the Zama series of carburetors. As with any small two-cycle carburetor, the internal diaphragms have a tendency to lose their flexibility over the lifetime of the carburetor and may need to be replaced using a carburetor rebuild kit.
  • 2 Disassemble the housing from the equipment to expose the carburetor. Locate the identification tag on the carburetor and write down the serial number. If the number begins with a CU, then the carburetor is a Zama carburetor.
  • 3 Order a carburetor rebuild kit for your particular carburetor model and refer to the instruction sheet that comes with your merchandise. The Zama rebuild kits cost an average of $8 to $10 each and will provide you with a very inexpensive way to prolong the use of your equipment.
  • 4 For detailed information and servicing guides about your Zama carburetor, refer to the diagrams and technical information provided by Zama at www.zamacarb.com/tips.html
  • Posted on Nov 14, 2010
    I have a 30cc ryobi trimmer that will start but not run unless the choke is fully on. The moment I use the throttle or turn off the choke ,it dies. what could be the problem? thanks.
    Hi Guy:
    The first thing I would check would be the fuel filter.
    Try pulling it out and giving it a really good clean.
    Probably a good idea to put fresh gas in at the same time if it's been sitting for a while.
    Aug 11, 2015 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
    No need to gap from a new spark plug unless the plug was dropped on the electrode.
    May 02, 2014 | Ryobi Garden
    I have a Ryobi 780r that won't run unless it is on choke. The moment I remove the switch from choke to run it shuts off.
    This means you have an air leak somewhere adding more air than fuel with the choke off. With the choke on it blocks off the fresh air coming in and mixes with the maverick air from the air leak. You need to find the leak and fix it or you may damage the unit
    Jan 10, 2013 | Ryobi Garden
    NEED TO REPLACE A BROKEN PULL CORD ON A RYOBI RY30550 TRIMMER/BRUSH CUTTER
    Here is a website with the parts breakdown and part numbers. You can order the parts from this website or just write down the number and call Ryobi to order it over the phone from them.
    1-877-545-4110
    Feb 02, 2011 | Ryobi Garden
    Blower will only run on full choke ryobi ry08578
    They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
    May 06, 2010 | Ryobi Backpack Blower 25.4cc
    What is the oil/gas ratio for a Ryobi RY30550 weedeater? 50:1? Thanks
    50:1 is too high. That is normally for a chainsaw which is much more severe duty. Normally for a weed whip its 25:1. They usually say on the gas cap but if not 25:1 is a good ratio that never fails (have done commercial landscaping for years) I use this ratio if I don't have a guide from the manufactor of the weed whip..
    Aug 30, 2009 | Garden
    My trimmer stopped working in the middle of trimming my yard. I now can no longer pull start my Ryobi Trimmer (ry30550). Cord seems to be stuck.
    Did you have the proper fuel/oil mix? I just had one that had the piston seize in the cylinder. After taking it apart and loosening the piston, I made sure of the mix and now it runs okay. You may have to get some gaskets that will break during dismantle. Hope this helps...Lee
    Aug 22, 2009 | Garden
    Need part no. for primer bulb for ryobi model ry30550
    NO PROBLEM,BEEN DOWN THAT ROAD. JUST REMOVE IT AND TAKE TO LOCAL SMALL ENGINE SHOP THAT DEALS WITH LAWN EQUIP,AND REPAIRS. THEY PROBABLY HAVE ON IN STOCK FOR ABOUT 5BUCKS OR THEY CAN ORDER YOU ONE. THEY WILL KNOW BY LOOKING AT IT.
    Jul 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Garden Logo
    401 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
