Question about Garmin nuvi 1310 Car GPS Receiver
My garmim nuvi 1310 has become realy slow on start up and freezes sometimes
4 Suggested Answers
SOURCE: how do i register my garmim nuvi 205w
This may be a repeat message. I am a Senior Citizen, not to bright with these systems. Can you help me Register my new garmin 205WT and find out how to down load most recent data.
Purchased today at Curry's
Thank you in advance
Ernest
Posted on Mar 02, 2009
marked
  • 6487 Answers
SOURCE: i need to restore the system of my garmim nuvi
You can reset the unit to default by doing this steps.
Holding your finger on the lower-right corner of the screen while turning on the unit and keeping the finger pressed until a message appear to delete the user data.
Posted on Jul 02, 2010
sharcnet
  • 2130 Answers
SOURCE: my nuvie 660 screen freezes,
If you press the on/off power switch and can toggle the screen, then he unit isn't locked up at all. The touchscreen is either intermittent or has failed and needs to be replaced. More info can be found here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jun 09, 2011
Tip
Garmin Nuvi 1310 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1310 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
___________________________
Garmin Nuvi 1310 Manual Download
Garmin Nuvi 1310 QuickStart Download
Garmin Nuvi 1310 Favorites Backup
Garmin Nuvi 1310 Hard Reset
on Jun 18, 2010 | GPS
Tip
Garmin Nuvi 1310 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1310 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Tip
Garmin Nuvi 1310 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1310 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1310 series GPS unit.
I hope that helps.
__________________________________________
Tip
Download Garmin Nuvi 1310 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1310 GPS?
Would you like a digital copy of the Garmin Nuvi 1310 Users Guide for easy searching of terms and quick reference?
The Nuvi 1310 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1310 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1310 GPS?
Would you like a digital copy of the Garmin Nuvi 1310 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1310 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1250 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1250 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1245 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1245 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1200 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1200 Manual Download
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
on May 13, 2010 | GPS
Garmin nuvi 1310 Car GPS Receiver Logo
384 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
