Question about Mitac Mio DigiWalker C310x GPS Receiver
The battery of my MIO Digiwalker C310X not charging. This unit however works fine when plugged-in to 12-volt car cigarette lighter power outlet. Could you please tell me how to fix it? Does it need new internal battery?
SOURCE: MIO DIGIWALKER NOT TURNING ON
hold the power button down for about 10 seconds. This will cause the thing to reboot....mine did the same thing. it will restart and should work ok.
Posted on Aug 04, 2008
  • 4 Answers
SOURCE: My GPS doesn't turn on
You need to purchase a new battery.
Posted on Feb 09, 2009
  • 45 Answers
SOURCE: Mio c310x GPS
don't change it by yourself, put it in service
Posted on May 02, 2009
SOURCE: Battery replacement of MIO C310x
http://hugginsnet.com/ilovemymio/index.php?topic=758.0
Posted on May 18, 2009
  • 32 Answers
SOURCE: broken lcd screen on mitac mio c310x
You will need to replace a new lcd screen for your cracked mitac mio c310x gps,you can try to contact her,probably she can help you.
Email/MSN:kingyijin@hotmail.com
SKYPE:keyudakim
Posted on Dec 20, 2009
Battery not charging and device will not turn on even when plugged in
I have 2 C310x's that had been sitting unused for a long time. When I went to use them I had the same issue. I almost tossed them, but decided to leave the one connected to the computer for awhile. After an hour or two it came back to life. Tried that with the other one and it also came back after an extended period of time connected to the computer.
Aug 05, 2011 | Mitac Mio DigiWalker C310x GPS Receiver
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Hi, i had a flat battery and took it off to charge it up,i came to put it back on but realized i had no key to get in the boot and obviously have no power and my car is now stranded on my drive going...
Go to any Automotive Parts Supplier (Advance Auto Parts) and tell them that you want a 9 volt battery backup that plugs into the cigarette lighter.......Or if you have a jump box,you with a 12 volt outlet plug on it,buy the cord that connects the outlet plug on jump box to the cigarette lighter outlet plug in the car.......Either option will give you the juice that you need.....I just hope that your boot is electronically operated
Mar 28, 2011 | 2000 Mercedes-Benz CLK
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Sean
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
Need a manual on how to operate mio digi walker
Mio still has a download/FAQ page for the DigiWalker C310x:
http://service.mio.com/M0100/F0140_1.aspx?Modelid=100086&ModelName=C310x
Click to the Downloads tab or User Manual tab for manuals covering the C310x hardware and the MioMap application. Manuals are .pdf format, english and french versions are available.
Sep 27, 2009 | Mitac Mio DigiWalker C310x GPS Receiver
Mio c310x GPS
May 02, 2009 | Mitac Mio DigiWalker C310x GPS Receiver
MIO C310x error upon starting MioMap: HardwareIDchanged
Turn the power switch on the bottom of the unit off for at least 30 seconds.
Jan 18, 2009 | Mitac Mio DigiWalker C310x GPS Receiver
Dec 19, 2008 | Mitac Mio DigiWalker C310x GPS Receiver
Mio Digiwalker C310
Turn off the power switch on the bottom of the unit for at least 30 seconds
Aug 25, 2008 | Mitac Mio DigiWalker C310x GPS Receiver
Mitac Mio  DigiWalker  C310x GPS Receiver Logo
91 people viewed this question
Top Mitac GPS Experts
Computer Links
Simon Flummox
Simon Flummox
Are you a Mitac GPS Expert? Answer questions, earn points and help others
