Question about GE Heating & Cooling
My oven is less than 1 year old. I don't think it is heating properly, i.e., too hot. Pies burn up, I'm using the same recipe and same temperature I've used for years.
  • Chris Lyon
    Chris Lyon May 11, 2010
    try posting in the oven category, not the airconditioner listing
    Scholar:
  • 104 Answers
Thanks!
Posted on Jun 20, 2008
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
My recipe says for cooking a xmas cake in 9" tin
The recipe is the one to follow, NOT stove. And always in center rack of oven. Too low burns underneath, too high burns top
Dec 18, 2010 | Siemens H 4680 BP KAT Stainless Steel...
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
Translate temp gauge numbers to degrees
I recommend you buy a cheap oven thermometer and check the oven temperature yourself. As a gasfitter I know temperature conversions (numbers to degrees) are approximate and I think may be done on purpose so consumers won't complain if they put a thermometer int he oven and it differs from the thermostat. Check the temperature in the centre of the oven. do not use pans and trays that fill the sheld as gas ovens need room to circulate the hot air. Also do not place items in the oven so the top of it is near the top of the oven - otherwise it will burn. I have found when cooking a chicken it needs to be turned otherwist the bottom of it may not be cooked.
Cheers
John
Nov 30, 2009 | Ovens
Smeg fautly themostat - too hot, burns everything
Sounds like thermostat faulty, make sure sensor is not detached or broken in oven, if still under 1 year old, then I suggest you contact service agent.
Pleas rate my solution.
Thanks.
Oct 10, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
Heating & Cooling Logo
35 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
