Question about Toro Garden
Rear wheels are locking up and mower can not be pulled backwards. This is a Toro20066
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
  • 109 Answers
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Posted on Apr 26, 2009
lester482529
  • 226 Answers
SOURCE: Mtd mower will not move forward or backward.rear
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
Posted on May 31, 2009
  • 12 Answers
SOURCE: the wheels lock up when i pull my lawnmower backwards
if you hold the clutch down to shift the gears after you release it if it doesn't move in reverse you have a gearbox problem and the easiest way would be to take it to a shop to have them fix it, it may not be too cheap but it is cheaper than getting the parts taking it apart and not being able to put it back together right. if you try to fix it yourself you could really mess it up and then it would end up costing you more than it would have to have just taken to the shop to start with.
Posted on Jun 15, 2009
mickey813
  • 472 Answers
SOURCE: Toro 20038 Lawn Mower rear drive wheel(s) lock
sounds like thw cabel may be jaming up not releasing if you fold the handels dowen that may whats wrong
Posted on Oct 16, 2009
HAVE A 4 YR. OLD REAR WHEEL DR. HONDA MOWER THAT THE REAR WHEELS LOCK UP WHEN PULLING IT BACKWARDS OR TURN REAL HARD.
sounds the belt may be too tight if it is the same belt that has been working maybe a weak spring on the transmission
Aug 17, 2017 | Honda Garden
Sears model 917370720/front wheels lock up
sounds like the transmission is not going in netural check and see if there is a blokage or is out of adjustment.
May 06, 2016 | Sears Garden
Why do my rear wheels lock up pulling machine backwards?.
your drive will driver dogs are full of dirt you need to remove both wheels and clean the dirt out the dogs are spring loaded be ready for parts to spring out maybe depends on how much dirt
Jul 05, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
Craftsman mower #247.887760 rear drive. rear wheels lock-up when you try to pull mower backwards
The rear wheels are locked to the drive train. To pull or push the mower, you must pull out the release probably at the back of the mower, near the transmission.
Gary
Jul 10, 2011 | Craftsman Garden
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
Sep 04, 2008 | Mtd 22" White Outdoor Self Propelled High...
Garden Logo
352 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
