posted by jrparker4 on Jun 18, 2008
I was given one of these televisions a couple of days ago because it was broken. The television powers on and you can actually watch tv, but the screen is green. Any ideas on what it might be and how hard of a fix?
Comment by jrparker4, posted on Jun 19, 2008
I think that is the culprit, thank you. I am also having issues with some wavy red lines and cannot align the red using the convergance utility. Is this another tube issue or a convergance issue?
Solution #1
posted on Jun 20, 2008
It would be unlikely that green CRT is the problem.
Check convergence menu and see if you can move the red and blue adjustment and if the green lines are normal.
If convergence is OK, then most likely, screen/focus pack. Resistor open in green part of screen/focus pack
easyab@hotmail.com
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
easyab@hotmail.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 18, 2008
You need a green CRT you can get a replacement CRt at the following link cheap and it comes with instructions on how to install it. takes about a hour to switch them out as theirs come with lens and coolant so you just have to switch them and plug it in.
http://servicemanuals.vstore.ca/
Comment by Slinteriors, posted on Jun 19, 2008
It could be related to the green CRT still as the green , red and blue convergence yokes all plug into the convergence board. I would address the issue with the green CRT and then see as one of the ICs controls the red and half the green convergence and the other IC controls blue and the other half of the green. So depending on the severity of the green CRTs short it can affect the red as well and quite possibly the blue. Let me know if you need more assistance with the issue.
Suggest a new solution for this problem
Post a New problem for JVC AV-48WP30 48 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
green convergence problem
ok i have a jvc av-48wp30, it... Answer This...
green problem
green problem
DIFFERENT convergence problem
clean behind screen
clean behind screen
need to remove screen spider... Answer This...
Analog JVC AV-2637S TV cannot...
Hi, I have a great but old JVC... Answer This...
Repair Service
Find Projection TV Repairman Near You:
