Question about Dryers
When i turn on my dryer the ignitor glows,gas flame comes on,stays on for a bit,has heat, flame goes out,after a while ignitor glows,flame doesn't come on
    President:
  • 3,074 Answers
Http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Nov 14, 2010
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
Gas dryer 4 yrs young and won't heat. Drum turns.
Dec 04, 2009 | Televison & Video
My dryer will spin but no heat comes from it.
Nov 18, 2009 | Food Mixers
Dryer does not heat
Nov 04, 2009 | Video Cameras
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
The Dryer Turns On But The Heat Does Not Come On.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Gas dryer turns on but does not heat up
Aug 05, 2009 | Dryers
Dryer does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
