Question about Sony Playstation 3 (PS3) Console
Moved playstation to friends tv played fine. Connected back to my tv power lights come on but No sound or picture yet all cables are ok
    President:
  • 1,139 Answers
You need to reset the display, follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start up with normal display settings. If you are using HDMI make sure only the HDMI cable is connected when doing the above steps.
Hope this helps and thank you for using FixYa
Posted on Nov 14, 2010
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
My console powers on. Light goes green. Controllers light up and stop blinking. Using HDMI cable. TV is connected to console. No signal being sent. TV working fine. Connected TV to notebook. No...
Have you tried replacing the HD-MI cable? there is a known issue with them. This sounds to me like the cable has mail functioned.
Any further questions feel free to ask.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 - picture doesnt come up on tv
hold center button for a couple minutes with all cables connected to your tv this will allign your system with your tv
Jul 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
No picture or sound
Have you re-connected the cable connection back into the TV from the player? There should be a lead going from the player & into the rear of your TV, I expect you are using a HDMI cable which has a a small flat-like end on the cable, re-connect this & try again.
Aug 22, 2009 | Sony BDP-S350 Blu-Ray Player
Controller all 4 lights are flashing and no sounds and no picture
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*Check that the input mode of the TV is appropriate for the connector in use on the system.
*There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
*If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
The wireless controller does not function.
*When using the wireless controller, you must pair it with the system and assign it a controller number. With the system turned on (power indicator on the system front is lit solid green), connect the system and the controller using the USB cable, and then press the PS button on the controller.
*Reset the wireless controller by pushing the reset button on the controller rear with a sharp-tipped object such as a pen.
Pairing your PlayStation 3 controller with another system will reset its frequency and you will need to pair it with your own again. If I recall, you cannot pair a controller through a USB hub, it must be a direct USB connection to the PlayStation 3.
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Was using hdmi cable for ps3 at home, moved unit to another tv at friends place, now no signal to tv through red whit and yellow cable adaptor
ALL YOU HAVE TO DO IS TURN OFF THE PLAYSTATION TURN IT BACK ON WHERE YOU SEE THE RED LIGHT NOW HOLD THE POWER BUTTON FOR LIKE 10 SECONDS AND IT WILL RESEST!!
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Rear projection TV! HELP!
Try looking over the tuner solder joints as well as the pins where Input board feeds to the singal board. Sounds like a solder issue or a weak capacitor. Check the solder with a good quality magnifying glass. Let me know how you make out and I will try to help you through the process to nail it down.
Mar 16, 2008 | Akai PTH5498 54" Rear Projection...
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
