Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Cuts out while driving
My 06 hd dyna lowrider stalls while riding. they have took all electrical apart and cant find problem. need help.
  • Anonymous Jun 22, 2008
    1991 fxlr-runs great 5 or 10 miles then starts running on 1 cylinder and backfiring-cools down-starts back, runs great short distance-same thing. changed ignition wires to the coils. changed coils, plugs and plug wires. anyone have this problem or an answer to mine?
Check the line for wholes
Posted on Jun 22, 2008
How do you change drive belt on dyna lowrider 2004 mine broke
Take a look at this video. Going to be similar.
Harley Dyna Glide EVO 1340 Drive Belt replacement ...
9k=? 29:10 https://www.youtube.com/watch?v=x4XBILULKck Apr 8, 2014 - Uploaded by Julian Sinclair Harley 1340 Drive Belt replacement on a 1997 Dyna Superglide. ... How To Remove & Install Rear Wheel ...
Mar 28, 2016 | Harley Davidson Motorcycles
2006 Harley Davidson FXDLI Dyna Low Rider cuts out while riding
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
2001 Dyna Lowrider Engine Cutting Out While Riding Harley Davidson Forums
http://kt-trading.net/mcimport/mc/HD/HD.Service.Manual.Dyna.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 16, 2017 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
How do I change the headlight bracket on my 2002 dyna lowrider
Hi Anonymous, you can cut and resplice the wires in the bucket or remove the pins at wire connectors on the other end. Good luck.
Feb 17, 2013 | 2002 Harley Davidson FXDL Dyna Low Rider
Will the rear wheel of a 2005 Fatboy fit the rear of my 1999 Dyna Lowrider?
Hi Dm_ryan, take a ride or drive over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary and offer professional advice and assistance concerning your issue. Have a nice day.
Aug 02, 2011 | Harley Davidson FXDL Dyna Low Rider...
How much air in the front and the back tires for a 2003 HD Dyna Lowrider are required
Max pressure is 41psi for thise tires. Tire pressure depends much on how you ride/drive.
depending on your size (160lb vs 300lb) you can start at about 36R 34F and go up. Too low, you damage teh tire, too high you feel every rock in the road.
Peace,
Mar 05, 2010 | 2003 Harley Davidson FXDL Dyna Low Rider
2001 Dyna Lowrider - Rear Brake Master Cylinder
Hi Klutzheffer, take a ride or drive over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary and offer professional advice and assistance concerning your issue. Have a nice day.
Jul 08, 2009 | 2001 Harley Davidson FXDL Dyna Low Rider
06 dyna won't start
Check your spark plugs. If they don't have your injector mix right, you could be fouling plugs...
Jan 07, 2009 | 2006 Harley Davidson FXDLI Dyna Low Rider
Lands Phones Logo
378 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
