Question about Goodman GMS90703BXA Heater
Heater doesn't come on? - Goodman GMS90703BXA Heater
    Guru:
  • 1,524 Answers
The electronic ignition system in a gas furnace is a modern development that allows more reliable performance than standing pilot furnaces, provides energy savings and contributes to better furnace efficiency (AFUE). With a standing pilot, found most commonly on older low efficiency furnaces (55% to 65% AFUE is not uncommon), a small gas flame is always burning and is known in the lexicon of American home repair as a "pilot light". The problem with this type of "analog" ignition is that it wastes energy by constantly burning gas and can sometimes be unreliable. These issues have led to the development of electronic ignition systems for mid to high efficiency furnaces that exceed the U.S. government's established minimum AFUE rating of 78%. The electronic ignition occurs typically in one of two ways:
  • Intermittent Pilot, or
  • Hot Surface Ignition The intermittent pilot system uses an electronically controlled high voltage electrical spark to ignite the gas pilot and then subsequently the main burners, when the thermostat calls for heat.
    The hot surface ignition system uses an electronically controlled resistance heating element not unlike a light bulb filament (and shown in the photo above), to ignite the gas burner.
    It is important to understand some of the other components of a modern furnace that you will encounter depending on the type of high efficiency furnace you have. Why? Because they can also come into play in repairing an electronic ignition furnace when it won't run properly. Let's take a quick review of the types of furnace designs and components found in high efficiency furnaces using electronic ignition.
  • Posted on Nov 14, 2010
    What safety issues should I look for in aquarium heaters?
    There are some safety precautions that you should take to make sure the heater is safe for use:
    • Since most heaters are made of glass, you should look for cracks. If there are visible cracks, throw the heater away because if water enters the heater it can cause electric shocks to the fish and even to the owner.
    • Make sure that the fish doesn't use the heater has a hiding space because it can get severely burned from the heater. Basically, just create safe hiding places with decorations for you fish so it doesn't have to hide behind the heater.
    • Never take a warm heater out of the water. Make sure you take it out after it has been unplugged for at least 30 minutes.
    Sep 05, 2012 | 1topstore Fish
    High speed doesn,t work on heater switch.
    Pull the heater control panel out of the dash and inspect the blower speed control switch, look for signs of a burnt connector to the switch, it will be discolored looking, if this is the case replace the switch and install a repair connector
    Jul 19, 2012 | Cars & Trucks
    The heater doesn't work
    your heater doesn't work any more
    Apr 23, 2012 | 1994 Opel Astra
    Heater doesn't work
    which heater? cabin heater or heater plugs
    Mar 03, 2012 | Honda Pilot Cars & Trucks
    Heater doesn't blow hot air
    Hi Tamara,
    Please review the following article to get an idea of what could be wrong with your heater.
    Why Is My Heater Cold?
    Nov 29, 2011 | 2001 Lincoln LS
    I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
    Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
    Sep 16, 2011 | 2000 Ford Focus
    We have a AO Smith water heater Model CYCLONE X1 s/n - 0813A001865 we are having issues with this unit. The unit iwas purchased in 2008. Can you send me information on this water heater. Our plumber bought...
    This doesn't sound fun. I would call the AO Smith technical support number and they might be able to help you figure this out. I hope this helps.
    Please vote for this answer. Thank you.
    Aug 22, 2011 | Smith A.O. SMITH Cyclone XHE Natural Gas...
    Can i use the dehumidifier without the additional heater? OR how can i improve the performance of the dehumidifier without increasing the output of the heater?
    Emma, your dehumidifier doesn't have a heater. I think you are confusing the Thermometer button as a heater. The Thermometer button is for setting the the ambient air temperature in the room, the unit is running in. It doesn't change the temperatue in the room one way or another. It's not necessary to set it, unless you're operating the dehumidifier in a basement. That's the only time it would affect the unit's performance.
    I hope this helped you.
    Jul 12, 2011 | DeLonghi Dehumidifiers
    When I auto start my 2007 chevy tahoe LTZ the air/heater doesn't come on. I leave it set the night before but it doesn't come on when I auto start.
    the circuit that powers the blower motor for the heater. if this is a aftermarket auto starter i sugjest taking it back to who installed it
    May 18, 2011 | 2007 Chevrolet Tahoe
    Heater fan doesn,t work
    if you are getting power at the fan plug, it is possible that the recycled motor is bad.
    Feb 04, 2009 | 1994 Cadillac DeVille
    Goodman GMS90703BXA Heater Logo
    624 people viewed this question
    Top Goodman Heating & Cooling Experts
    Dan Webster
    Dan Webster
    paulcarew
    Brandon Berry
    Brandon Berry
    Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
