Question about HP D1560 Deskjet Printer InkJet
I have just fitted refilled cartridges. I aligned them without any bother, but now I am trying to print I am being told that there are cartridge problems, and the on/off light is flashing
  • Bob Metcalfe Nov 15, 2010
    It was the answer I expected, but it was nice to have it confirmed by an expert. The speed with which the answer came was appreciated.
    Top Expert:
  • HP Master
  • 80,417 Answers
You will most likely need to replace the cartridges, that is the most common reason for this problem, I have seen this same complaint dozens of times on HP printers including my own (I have owned 4 HP units). The only thing I can suggest you try is this, use a cotton rag and clean the contacts of the cartridges and make sure the pins are clean in the printer where the cartridge sits.
Posted on Nov 14, 2010
My HPDeskjet says alignment failed. Cartridges are set to default quality. I just replaced the ink cartridge.
Are they refills? HP will not accept refills at all . I know from experience.
If they are HP cartridges then the print head is probably clogged. ( the big square tray that the cartridges fit into)
You'll have to remove it (just a latch or clip. Look in manual) and replace it. They can't be cleaned. I've tried on several different models.
Jul 14, 2016 | HP Deskjet 3050A e-All-in-One -...
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Can Dell A960 ink cartridges be refilled and re-used or not?
A lot of inkjet printer manufacturers make you purchase their ink cartridges by installing a chip in the cartridges so when the cartridge is empty it cannot be reused by filling the cartridge.
Jan 28, 2013 | Dell A960 All-In-One InkJet Printer
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • The paper has already been printed on or is colored paper.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Hi Folks, Sorry to bother you but i have HP 2575 all in one for past 3 years,and until now had no problems..I recently changed my colour ink cartridge cos the old one indicating low toner and some colours...
Try to clean the cartridges by taking them out and trying aligning the cartridges again... try the alignment if you have any software named as image zone or solution center
Oct 21, 2010 | HP Photosmart 2575 All-In-One Printer,...
Low ink indicator and I refilled my cartridges, how do I get my printer to recognize they are now full?
Open the Lexmark control Panel and select the Ink Cartridges Alignment tool. In the windows should be a place where you can select whether you have installed new ink cartridges. Also, make sure you do the alignment before trying to print. Finally, if you're using replacement type cartridges made by a third party company, they may not be detectable by the Lexmark system... many are not 100% compatible and don't have the electrical connection properly designed to be readable by the Lexmark software.
Oct 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X2580 won't print after cartridge refill
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Lexmark cartridge... see if that solves the problem. Which it very well could work off the Lexmark brand again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
May 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Refilled Cartridge
How can I Reset Memory For Lexmark X4550
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell All-in-One Printer 964
I tried all the above and it is stll not reading the ink levels.
Dec 22, 2007 | Dell Photo 964 All-In-One InkJet Printer
HP D1560 Deskjet Printer InkJet Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
