Question about Yamaha RX-V2400 Receiver
How to replace fuses for yamaha rx-v2400 receiver
SOURCE: Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Posted on Oct 17, 2007
bluenadas
  • 203 Answers
SOURCE: proplem Plowen Fuse
If you've replaced the fuse and it blew again, you most likely have a blown Amp. And when an Amp goes other things can go with it as well.
Posted on Nov 19, 2007
SOURCE: Yamaha AV Receiver RX V2400 - Shuts off
I've been having the same problem for 3 months. Checked connections, sent unit out for repair (3x), contacted Yamaha (no help at all) and still the same problem. I've spent over $350 in repairs and I'm very frustrated. I think I'm going to just buy a new receiver (not Yamaha).
Posted on Feb 17, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
Only one side speakers are working...is it a fuse?
Not unless your speaker is has fused input protection. if no speaker will produce any sound, it may be the output transistors. Make sure the balance is balanced, and correct polarity. Get an RA(return authorization) for the Yamaha USA Repair center if you can't fiqure it out. The do good work for reasonable rates.
Sorry I couldn't make it easy for ya.
Sep 03, 2011 | Yamaha RX-V2400 Receiver
HOOK UP YAMAHA RECEVERS M-85
You would connect the rx-v2400 record output to the power amp input. You might need to Clarify your question here in more detail. Larry's Electronics
Apr 26, 2010 | Yamaha RX-V2400 Receiver
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
Jun 12, 2009 | Yamaha RX-V2400 Receiver
Apr 21, 2009 | Yamaha RX-V2600 Receiver
Proplem Plowen Fuse
Nov 19, 2007 | Yamaha RX-V2400 Receiver
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400
Jun 04, 2007 | Yamaha RX-V2600 Receiver
yamaha receivers protect themselfs when the power transistors at the output section are shorted, I just posted what you can look for this failure.
Feb 13, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400 Receiver Logo
163 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
