Question about Vinotheque Whisperkool 3000 Wine Cooling Unit (Max Room Size = 650 cu ft)
Whisperkool 3000 XLT started icing in front. I followed internet instructions and took the unit apart, making sure that the drain tube in front was properly installed and not plugged. There were no problems there. Put the unit on a timer so that the ice could melt between cycles, which worked except the cellar couldn't get down to 55 degrees. Now the unit runs but the air coming out of it into the cellar is at ambient temperature (66 degrees). I suspect it's completely shot, but at $1,500 to replace it can it be repaired, where, and would it be worth the cost. It's out of warranty. Thanks
3 Suggested Answers
SOURCE: Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
Posted on Jul 14, 2010
bobicehouse
  • 1524 Answers
SOURCE: The unit ices and only cools to 65 rather than
Have you cleaned the condenser coils ? Is the unit too close to the wall ?
Posted on Dec 18, 2010
Ice Build up on freezer floor then leaks out the front on to the floor. Drain tube is not plugged. The ice builds up in the drain trough then over flows on to the floor of freezer.
Not usually, will have to thaw, then run pan of hot water through drai. Can pull lower vent cover off to make sure it runs into drain pan under fridge. Drain may look clean but tube may not be. Can take wire from hanger to clear as well.
Sep 29, 2015 | Refrigerators
Whisperkool 1600 xlt developed a drip from the right fan after many years of trouble free operation. What could be causing this?
http://www.luxewinecellars.com/sites/all/files/product_downloads/whisperkool-xlt-owners-manual.pdf
i was just reading the manual for you. This make not be the exact manual But once a year you have to clean the fins, bleach the inside etc. make sure the drain hose is not blocked with goo, or deposits etc.
Oct 20, 2013 | Furniture
The unit ices and only cools to 65 rather than the 55 degrees that is set
Dec 17, 2010 | Vinotheque Whisperkool 3000 Wine Cooling...
It will not drain , the screen is clogged from the inside, i took it apart , and the round screen doesn't seem to open to get it cleaned. how do I open it?
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jun 02, 2010 | Frigidaire 24 in. PLD3465REC Stainless...
Hi, Bob:
Sep 25, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Jan 02, 2009 | Vinotheque Whisperkool 3000 Wine Cooling...
Ice maker makes hollow ice! Why?
Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be that the timer needs to be adjust.
If the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
To adjust the timer, follow the instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 16, 2008 | Amana AFD2535DES French Door Refrigerator
Water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
124 people viewed this question
Top Vinotheque Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vinotheque Refrigerator Expert? Answer questions, earn points and help others
