Question about Belling Ovens
I have a belling 640ss mk2 i have replaced the element in the main oven and it got hot but know its burning everything we try to cook I made sure I got the right element it seems to be stuck at one temp very hot could I have put the middle wire on the wrong contact as the element I received had two middle connectors but the one that was on it from a previous repair which was supplied by a guy who fixed it last time which only lasted 6 months only had one but there was only one wire. I hope you can help Regards Sally
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Posted on Nov 25, 2008
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
SOURCE: Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Posted on May 10, 2010
marka19
  • 1430 Answers
SOURCE: Since my main oven element
Thuis sounds like the relay on the main control board has fried. It is stuck in a closed positon(on). The relay cannot be replaced the whole board must be replaced. Here is a link that should help
Replacing oven ERC you can also enter your model# for diagrams and illustrations of your specific model.
Posted on Nov 17, 2010
What would cause the broiler element to override the baking element? My oven has lost its mind. It doesn't matter what setting I use, The broil element takes over and burns everything. Please help.
Not 100% sure but my guess. Most electric ovens usually bake with both elements on. The bake element(bottom) is usually on at full power with 240 volts to it. The broil element(top) is usually on at 1/2 power 120 volts to help even out the temperature. My guess is your bottom element is not coming on at all either because it is burned out or something in the control system. So what is happening is the oven is trying to heat to the set temp with only the top element keeping it on much longer than it normally should be on and burning everything. Now if you set the oven for bake and the top is on red hot, you have a control system problem something like a bad selector switch or main control board if the oven has a electronic control.
Apr 10, 2015 | Ovens
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Apr 03, 2010 | Belling XOU174 Electric Single Oven
I have an Ariston electric oven that seems to get too hot & burns
You can try going to a lower wattage element. EX: Our oven can take a 2500 - 5500 watage element. The lower the wattage, it won't heat up as fast/hot.Plus it saves on your power bill over time. Go to the Ariston website, or find your element number and check the web for a lower wattage.
Jan 26, 2010 | Ovens
Hotpoint UD47 electric oven not hot enough
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
78 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
