Question about Sony Playstation 3 (PS3) Console
When i turn on ps3 ... flashing red light (normally shouldn't be flashing) i press it and a green light appears then a flash of a blue light next to it and after that a quick yello light
    President:
  • 1,139 Answers
This is unfortunately what is known as the Yellow Light of Death (YLOD). It is a very common problem with the PS3 and is something that is caused by a general hardware failure. When Sony produced the PS3 they used lead free solder as it was cheaper and less damaging to the environment when recycled. Unfortunately lead free solder is not as flexible as leaded solder so when the console heats up and cools down hairline cracks appear in the solder joints and there is a bad electrical contact. This then makes the PS3 go through the yellow light start-up procedure instead of coming on normally. There are ways you can fix this, by reheating the solder joints using a heat gun and some flux. This may work for a random amount of time though as once you get the YLOD error you can never 100% get rid of it unless you replace the motherboard. If you look on google there are some guides out there explaining how to use the heat gun method.
However after reading the above and your PS3 is in warranty DO NOT attempt any repair yourself. Your PS3 is covered under a years warranty from Sony and they will replace the console if you get in contact with them.
You could also look at some console repair specialists on ebay and such that charge a small amount to do the repair, usually around £40-£50. If you come from the US there are lots of companies there too and I am sure they are just as cheap.
I hope this helps and thank you for using FixYa
Posted on Nov 14, 2010
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
I go to turn the sony PS3 on and the green light comes on for about one second then a blue light flashes next to the green light and then a red blinking light flashes until I turn the power off. I just...
Flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3
better u download repair guide
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
I was playing online when suddenly my ps3 switched off, when i tried to switch it on by touching the touch sensor when the indicator was red, it turned green normally as soon as the normal green and blue...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Ps3 wont turn on???
Your system is getting hot......Clean the dust from the unit with a vacume...not a can of air, Canned air will only push the dirt further into the unit. also you can buy an intercooler for the ps3 nyco makes one that actually forms to the ps3
Sep 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
