Question about Christie RoadRunner LX100 Multimedia Projector
Temp lamp is on.
Afew seconds after on the proyector, the temp lamp is on.
the lams a new. wath ca i do?
  • tetraedro Jun 19, 2008
    the lamp temperature is still on Iclean all the ventilations, retire the cover change the lamps, but after a few seconds, the temperature lamps lamp is on and the proyector turn off. all the internal fans work ok.sombady knows were can I get the repair manual?
    jaja,thanks, but I tryin to avoid send the proyector to service. where is the thermal chip? where can I get a service manual?
As mitsbushi not having support can we get this temperature switch in the market .please share me the image we have 3 unit with us haing temparature problem
Posted on Apr 07, 2015
    Guru:
  • 859 Answers
Your problem is probably related to a bad thermal temp control chip and you should return this for a replacement explaining the problem.
Regards,
Worldvet
Posted on Jun 19, 2008
  • 1,879 Answers
Overheating
Posted on Jun 18, 2008
  • monk3ybidzness
    monk3ybidzness Jun 18, 2008
    check the ventilation - then re seat the lamp (careful it's hot)
    if the still persists (with enough ventilation / the unit was working perfectly with other/previous lamp) it is the lamp that is faulty. contact the lamp manufacturer for replacement.
I have a BenQ proyector model mp510 wich lamp doesnt start, I would like to Know how to check the lamp or how determine or find another problem.
best bet is speaking to BenQ direct - or at least where you bought bulb from and get them to take a look - does the bulb look ok or have you been unlucky and got broken bulb still?
if you can't get on, then can't see menu which means youre stuck.
sorry
good luch
Jan 28, 2013 | BENQ MP510 Original bare projector lamp...
How reset lamp timer of a csmart sv2 lc 4433 proyector?
Press menu
select settings
select lamp counter
press OK for 3 seconds to reset
press menu to exit
Feb 23, 2011 | Philips cSmart LC4433 LCD Projector
I had my projector on yesterday for the first time in 2 years, half way through the movie it stopped working. The projector fan is still going but there is not blue light comming from the globe. Does this...
Generally, proyectors has more than one fan. One fan is uses to cold the lamp, the second one to keep the color wheel cold. Other one could work with the micro.
If you don't take care to keep the item clean of dust, proyector gets hot and can be damage.
Dec 20, 2010 | PLUS Vision Corp. U3 880 Multimedia...
I've just installed a new lamp, but the lam and temp indicators are flashing. Thisis supposed to mean that the plastic compartment door is not closed properly. But it is. Help please.
Try taking the door off and manually hold the switch down. If its still gives the error, you have two choices. 1.) Replace the lamp switch or 2.) cut the wire and splice them together.
Apr 06, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My power supply is not working
That problem is usually related to failed capacitors on the power PWB. You can get a kit called the V26 Power pwb repair kit at the following link which contains the replacement capacitors and a a CD with instructions at the following link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Proyector 3m mp 8670
the lamp is ok
the lcd panels were fault
you need a new one
USD160
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Nov 06, 2008 | 3M Projector lamp Projector Lamp
Christie RoadRunner LX100 Multimedia Projector Logo
1,790 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
