Question about Dell 1600n All-In-One Laser Printer
Will not print
States "out of paper" the try is full, I have re-started it, un plugged it, removed and replaced the tray, search for an obstruction underneath the pick up.
I had this problem. I re-installed the drivers and it's back in business!
Posted on Jun 30, 2008
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Paper jam
Hi Fred,
Turn the printer off and on.
Check through the paper paths for any obstructions.
Remove any stuck papers manually.
Solved?
Disconnect the printer from PC,unplug from power and reboot your PC.
Re-connect printer and start your PC.
Avoid filling the paper feed tray to capacity.
Try printing now.
Hope this helps.Thanks!
Jan 01, 2012 | Office Equipment & Supplies
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
Will not print, but ready light is on and tray is full of paper.
remove the paper and look down in the slot, sometimes the (brown) guide mylars get flipped up out of place so that the paper does not settle all the way down, and it blocks the paper path.
Mar 21, 2009 | HP LaserJet 6L Printer
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Paper jam..cartridge back and forth
hi
This clearly indicates that problem is with the rollers in the paper feed tray..to clear the obstruction-fold a sheet of paper 3-4 times lenghtwise to make it thick..insert this into the paper feed tray,behind the rollers-move it left right a couple of times....repeat this a couple of times-if no go...call tech support..printer would be replaced if in warranty...good luck
Jan 24, 2009 | Office Equipment & Supplies
Paper does not feed
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets try few troubleshooting for paper Jam issue.
locate and slowly pull out the stuck paper, perform the following steps:
1. Turn off the printer.
2. Open the printer cover.
3. Locate the stuck paper.
4. Remove the paper.
5. Close the printer cover.
6. Power the printer back on.
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Extend the front paper support on the printer.
Try a Different Piece of Paper in the Printer
1. Take the top 10 sheets off of the **** of paper.
2. Verify that the remaining sheets of the **** are not wrinkled or dirty.
3. Replace the remaining part of the **** back in the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
When there is no different print media available, take out the top half of the stack and flip it over.
Try holding the printer upside down and shake it moderately
Make sure you remove all the cables from printer before performing it
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Nov 02, 2008 | Dell 926 All-In-One InkJet Printer
Printer won't feed the paper through.
3. Close the cover.
Aug 24, 2008 | Dell 922 All-In-One InkJet Printer
Paper Will Not Feed Through
3. Close the cover.
Aug 13, 2008 | Dell 924 All-in-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
