Question about Peg Perego John Deere Gator HPX Ride on Toy
Probably need a new shifter switch, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
SOURCE: PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Posted on Oct 17, 2008
SOURCE: old john deere gator and battery new charger still will not move
Could be several things. Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger. You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Posted on Jun 23, 2009
Oct 28, 2014 | John Deere 2014 Gator XUV 4x4 855D S4
Aug 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
Jul 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Sep 12, 2011 | Peg Perego John Deere Gator HPX
Aug 29, 2010 | Peg Perego John Deere Gator HPX Ride on...
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Mar 19, 2009 | Peg Perego John Deere Gator HPX
Jul 19, 2008 | Toys
Apr 22, 2018 | The Toys
Apr 18, 2018 | Toys
134 people viewed this question
