Question about ViewSonic Q241WB LCD Monitor
ViewSonic Optiquest Q241wb faint vertical lines about 2 inches apart across the picture. The monitor was MFG Jan 2008
4 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
MrDallasIT
  • 91 Answers
SOURCE: I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
Posted on May 14, 2009
budmrtn
  • 11361 Answers
SOURCE: ViewSonic Optiquest Q19wb LCD Monitor goes blank
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Post pictures or send them to me budmrtn@aol.com
Posted on May 17, 2010
Vertical pink line across dell p2210 monitor
Mine has a green line. I changed the background to green. It's broken, you can buy an new one or cover it up.
Sep 07, 2013 | ViewSonic OptiQuest Monitor
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
My Monitor just stopped working. No pop, no fade, just dead. Oh, sorry it is an optiquest Q19wb says manufactured in 10/2006. bought 1.5 years ago at best buy. Worth trying to fix or dump it??
Optiquest is the Viewsonic low end products. You can take it apart and look inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic Optiquest Q7b 17" LCD Monitor has a fuzzy picture
LCD monitor needs to be fed with native resolution from the PC video out, this monitor native resolution is 1280x1024 @60Hz, try that setting to see if it helps before opening up the monitor to look for failed components.
Mar 29, 2010 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
May 13, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Optiquest Q19 monitor adjustment off
Finally found out that the Optquest monitor is an viewsonic brand monitor and finally downloaded the manual.
Jan 10, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
"out of range message"
I have the exact same problem. Using RBG cable supplied by Viewsonic for Model Q241wb
Jan 16, 2008 | Computers & Internet
ViewSonic Q241WB  LCD Monitor Logo
249 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
