Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Is there a manual for an AirMate model AM78HC4V.
  • sask_icf_bui Nov 17, 2010
    Thanks, but nothing there. The model seems to have vanished.
  • Dewalt Master
  • 7,733 Answers
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
2 Suggested Answers
  • 12 Answers
SOURCE: emglo airmate AM78HC4V; when trying to start
I had the same problem. Replace the motor capacitor. small white cilinder part with two wire plugs conected to it. This will have a single bolt holding it to the frame casing, you will find it under the black plastic shroud that covers the motor. Take it into any electrical or compressor shop and they will check it for you. costs about $35.00.
Posted on Jul 07, 2009
What kind of oil should i use in airmate compressor?
ISO 100/SAE40, non-detergent, premium air compressor oil
Hope this helps.
Jul 29, 2017 | Air Tools & Compressors
My elmglo airmate hand held wont turn on relay switch wont work
the relay switch is the air pressure switch to turn the compressor on and off after reaching set air pressure; most have a button it. also just may be broke..
Sep 02, 2015 | Cars & Trucks
Where is the oil drain for am78hc4v
There are four screws that hold the end cap on the pump. The fifth screw at the bottom, middle of the cap is the oil drain plug.
Mar 14, 2012 | Dewalt d55151 factory reconditioned emglo...
Emglo airmate AM78HC4V; when trying to start compressor the motor will only hum
Jun 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
EMGLO AM78HC4V pump oil
use sae 30 non detergent oil in this compressor let me know if you got any other qeustions
Jan 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Air compressor does not regulate pressure to set point.
Emglo airmate compressors are set from the factory to shut off at around 125psi. There is an adjustment (remove cover to pressure switch) that will controll the cut-off pressure but it is not recommended changing the factory setting. There is also a safety valve installed that will open at about 160psi. It is a small brass device with a pull ring. When things go wrong with the pressure switch (rectangular box with power cord coming out of one side) the safety will pop open. There is a pressure regulator with round knob on panel that will lower the pressure to the tool, however this regulator does not control the pressure switch. Let you compressor run untill it shuts off and verify pressure to be about 125, if it is then all as well. Good Luck
Jan 03, 2009 | Dewalt d55151 factory reconditioned emglo...
Compressor will not shut off
The switch is bad, replace it, this should solve the problem.
Nov 17, 2008 | Dewalt d55151 factory reconditioned emglo...
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
741 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
