Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
I have a kenmore front load washer. I was told to remove the kick plate to check the filter but my manual has no instructions.
  • 347 Answers
You need to remove the lower front panel (three small screws at floor level) after removing you will see the drain pump right there in the middle. Place a shallow pan under the front of the pump, then remove the cap on the front of the pump,clean out all the debris and wash off then line up the marks on the cap and housing to reinstall That's all there is to it.Good Luck
Posted on Nov 14, 2010
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Where is the kick plate and how do I remove it?
The kick plate is the piece at the bottom front of the washer. The kick plate is often attached by friction fastener and is removed by prying it off
Dec 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle light keeps on blinking washer model 11045091404
Remove the bottom kick plate and clear the filter. Post back the results.
Nov 20, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore fornt load washer will not drain
Remove the lower kick plate and clear the filter.
Nov 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
In the fall of 2009 I bought a front load 3.5 super capacity washer. All off a sudden it wont drain or spin and makes a buzzing/humming sound. Cancel and the bowl spins freely manually
Hi
You have something caught in your drain pump. If you have the manual for your machine, it would have instructions.
You need to locat and open the filter for the pump. Please note the machine is full of water, and when you open the filter cap, all the water will flow out.
I am not familiar with Kenmore as we do not have this brand in Australia. However, with most machines the filter is located at the front right bottom of the machine. Some have a flap open door then a twist cap. Other machines have a kick plate with needs to be removed, then a twist cap.
Some machine shave a hose bleeder next to cap which allows you to drain water out manually before opening the cap.
Once you open the cap clean filter and also check inside the cavity with a torch to see if anything is blocking the pump propellors.
Sometimes you are not able to physically see the pump propellors, so the pump needs to be removed and checked.
Ash
Sep 11, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
The washer will not spin
It could have an object in the pump. Your tech sheet will help. Remove the kick plate to find the the tech sheet and clean out the pump filter. Here's How
If yours is an affinity model then you might have a clogged hosethemobilian_903.jpg
Affinity service manual
If it is a duet click here
Jan 16, 2011 | Kenmore HE2 Plus Front Load Washer
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
LOCATION OF LINT TRAP?
Remove 3 screws from the bottom front panel and drop it down. The pump will be in front of you on the bottom.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Need to clean my filter on Kenmore Elite he3t--where is it?
FIRST GET ALOT OF TOWELS MACHINE HOLD 3 GALLONS OF WATER STILL THERE IS A PLASTIC PUMP W/ ROUND HANDLE REMOVE HANDLE COUNTER CLOCKWISE AND REMOVE WHATEVER IS IN THERE
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
