Question about Acoustic Energy WiFi Internet Radio
When i scan for network, radio finds linksys, i press select. Screen says unable to associate, then says empty. We have had this radio for a few years, so we know a little bit about how to be it to work. thank you for any help, we love our radio
  • 12,061 Answers
Www.ccrane.com/...manuals/acoustic-energy-wi-fi-internet-radio.pdf
please find your manual above, i think what you need to do is reset the unit, factory reset and then re-setup the station all again.
You may need to clear out any "old" settings that may have changed, and conflict with some existing settings.
Posted on Nov 15, 2010
Lexmark x6180 Printer. Unable able to Scan. I turned on my printed and selected "Scan" button, located with two other buttons ("Copy" and "Fax" under the section titled...
On the printer operator panel, press Black to begin a black and white scan or Color to begin a color scan. You can rename the file only on your computer once the scanned file is displayed.
Jun 19, 2011 | Lexmark X6180 Printer
Trying to hook up wireless internet.Have tried with or wireless netgear support and could not help us.
To set up wireless internet, you must navigate to the settings tab, then go down to the bottom of the settings list, and click on "Network Settings". After that, another menu should show up, click on "Internet Connection Settings". You should get some sort of prompt, hit "ok" or "Yes".
It will then ask you for a "setting method", this will determine how many options you can change. Press "Easy" (Unless you need to give the Ps3 advanced information, but in most cases Easy is sufficient). Select wireless. Then, select "Scan". This will scan for all available wireless networks. Once you find your network, go to it with the D-Pad, and press X. "SSID" should show up on the screen, simply press the right arrow on the D-pad. It may ask you for a security setting, chose the password encryption that is set on your router (WEP, WPA,none,etc). Then enter your password on the next screen.
After that, you can skip the next few screens by pressing the right arrow on the D-Pad until you get to the last setup screen, a "Testing" screen. Press X at that screen, and it will test your network, and hopefully connect you to the internet.
Mar 29, 2011 | Sony Playstation 3 (PS3) Console
My wirelessnetwork screen is blank and i have refreshed and still nothing. i have had this linksys wireless card installed on this computer before,
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you dont know how to uninstall the Adapter,
Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck.
Jan 11, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
How to find more wifi connections with my Linksys WPC54G? I can get connections (sometimes) but would like to find more options (stronger connections).
Upgrade the drivers for the adapter for better connectivity , excellent signal strength and enhance performance.Go the following link:-
http://www.linksysbycisco.com/US/en/support/WPC54G/download
and under select hardware version select the latest one from there , in this case it will be v7.1.
After selecting the v7.1 download the driver associated and enlisted below which will be Ver.4.1.2.95.
Dec 05, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
How do you setup an XBox to a Linksys WCG200? We have tried each step suggested by the Xbox setup screen but cannot connect with my router.
If computers can get online using the router then follow the steps below:
1. Turn off the Xbox and connect a straight-through cable from the Xbox to one of the numbered ports on the router.
2. Turn on the Xbox without a CD on the tray then the Xbox Dashboard will appear.
3. Select Settings and then press A on the controller.
4. Then select Network Settings and then press A on the controller.
5. Select IP addresses and then press A on the controller.
6. Under Configuration, select Automatic and then press A on the controller.
7. Then press B on the controller, to go back to the Network Settings screen.
8. Then select DNS servers, then press A on the controller.
9. Under Configuration, select Automatic and then press A on the controller.
10. Then press B on the controller, to go back to the Network Settings screen.
11. Then select PPPoE settings, then press A on the controller.
12. Under configuration, select Off and then press A on the controller.
13. Then press B on the controller, to go back to the Network Settings screen.Then click Connect.
Dec 04, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
How do you connect the new PSP Go to Linksys WRT300N router?
On the PSP make sure the WLAN Switch is turned on. To connect to your router, go to System Settings > Network Settings > Infrastructure Mode then select the Network that you want to connect. If it's Linksys, select Linksys and press X. Select Scan and choose the wireless network and Enter. If it asks you for network key, type your wireless network key and connect. That should do it.
Oct 06, 2009 | Linksys WRT300N Wireless Router
Linksys wireless-g wmp54g cannot access internet
Hii
Solution- For windows XP
#1--On your computer in the right lower corner you will a green icon for linksys adaptor --
Right click on linksys icon- select option "use windows wireless configurastion --- Select Yes ---
Green box turn Grey --
#2-- Start - Control Panel-Network Connections ---
Rigfht Click on wireless network connection- Selct View Available wireless network - Here you can see your network --
Mar 29, 2009 | Linksys Wireless-G WMP54G 802.11g/b
I have a MTX8000 Handie-Talkie FM Radio It is a 16 channel radio
You're on scan mode but have no channel in scan list. You might have to go to scan PROGRAM mode and select the channel you want to scan then press a side button to put that channel in the scan list then will scan.
radcom907
Mar 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Unable to connect to the router
Ok make sure the following is done:
Use the Linksys CD to do the network set up.
Set up the SSID in router settings.
Set up the admin password on the router.
Set up WEP encryption and an associated password.
Make sure in network settings that Vista networks type is set to 'Private'
Oct 21, 2008 | Computers & Internet
Can't get ATS to function per instruction manual
You probably have to set the scan function to ATS mode by turning the radio off, pressing and holding the F6 button for 2 seconds, then releasing, then quickly pressing and releasing the F6 button to step through the 3 scan modes. The display will show which mode is currently selected.
Aug 17, 2006 | Eton E5 Radio
Acoustic Energy WiFi Internet Radio Logo
176 people viewed this question
Top Acoustic Energy Televison & Video Experts
Are you an Acoustic Energy Televison and Video Expert? Answer questions, earn points and help others
