Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
We have a Canon MP250 Pixma printer that recently has started acting up. When you prompt it to print...the paper feed causes a jam. The paper tilts to the right then jams. I unplugged it and looked in the paper loading area...cant see a thing....I even prompted through the cleaning process...no help there...can you help me?
  • Tom Frazee Nov 15, 2010
    Thanks for the quick reponse...I tried what you suggested...but the problem still exists...any other suggestions
    I did what the technician suggested and still had a problem. I then put a very small mirror in the paper supply slot and discovered the problem: The problem was that my sons cuff links had fallen in the paper supply opening and couldn't see them.. after alot of patience and using a jumbo paper clip to make a makeshift hook....I was able to free them and remove them. I tested the machine and we are back in business....Thank you for your great service...
  • 629 Answers
Try to adjust the paper guides, then check the rollers for any damaged or dirt which you may need to clean with a dry cloth. make sure they are align, Then use new set of paper and test the printer again. It seems that something is causing the paper to tilt to the right side causing the paper jam.
Posted on Nov 15, 2010
  • Rodie Nov 15, 2010
    try removing and reinstalling the cartridges, then print a test page and perform the catridge aligment process and see if that helps
  • Rodie Nov 17, 2010
    glad that you got it sorted. sure is happy to know that you're back in business again with your printer. :)
Paper jam in a canon MX 926
Here is a great tutorial for a similar model, it is likely to be similar:
http://ugp01.c-ij.com/ij/webmanual/ErrorCode/MX920%20series/EN/ERR/1313.html
Be careful and act slowly when fixing the jam, it is easy to cause permanent damage.
Oct 03, 2013 | Canon Pixma Mp250 Allinone Inkjet Photo...
My Canon PIXMA MP250 Inkjet isnt working?
Does the printer power up?If not,check the power cable or probably replace it.
If it does power up,disconnect everything including the usb connections and also turn off your PC.
Wait a while and then re-connect them all.Start the PC first and then turn on the printer.
Now try printing.If still cant print:-
  • You might have run out of ink.Check the cartridges and replace any dry ones.
  • Check for paper jams on the paper paths and manually remove any stuck papers.
Hope this helps.Thanks!
Oct 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do I fix paper jam?
There is no way to fix your paper jam, but feed the paper well in your printer while printing.. thanks
Aug 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
It won't feed paper
Hello, Welcome to Fixya.com
The paper feeder sensor in the APF is what might be causing your issue.
1. Check for any jammed paper in any part of the printer.
2. A jammed piece of paper can cause the paper not to feed.
If that is not the case you might need to have this looked at locally.
Regards
rulds2008
Mar 22, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
797 people viewed this question
old marine
old marine
