Question about Garden
I need a replacement for a carborator primer bulb.I cannot find a model number on the blower and dont have a manual It's a 2-cycle. Can you help?
  • 1,498 Answers
There are only to or three styles and they are available at lawn & garden supply stores at a cost of $5-6.00 each. Bring the old one to match them.
Best regards
Mike
Posted on Nov 14, 2010
How do i replace primer bulb?
What is the MODEL of your saw.?
I'm guessing its possibly the PP4218 here's a couple of manuals to help you. Its a pretty simple process of removing one and putting the pipes back on.
http://www.poulanpro.com/ddoc/PPOO/PPOO2010_USen/PPOO2010_USen__115156526.pdf - owners manual
http://www.homedepot.com/catalog/pdfimages/24/2470e23d-a484-4d9a-adfc-2bb17fd6d798.pdf - parts manual
May 01, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
After replacing primer bulb, engine hesitates and will not run full throttle
Make sure you connected the lines correctly. If this is a primer assy that has the 2 barbs on the back here is a picture of how the lines should be connected to it as well as the carburetor
Now if this is a primer bulb on top of the carburetor then disregard the previous answer because in this case, your carburetor needs the H needle adjusted. Go on you tube .com and type in how to adjust a 2 cycle carburetor. Many videos will appear.
Nov 21, 2015 | Garden
Fuel primer
The primer bulb fills the bowl of the carburetor on initial start-up. Most primer bulbs are depressed 4-6 times. Set the choke at half and either pull the starter cord four times. If it doesn't start, re-prime and take the choke off.
Mar 16, 2014 | Garden
Just replaced carborator and now it won't start. any suggestions?
you might have primer bulb lines on backwards or the gasket between carb and motor is upsine down
Aug 25, 2012 | Craftsman 2 Cycle 25cc Handheld Leaf...
The carborator iss not adjusted
The idle screw is in the hole right above the primer bulb. Turn clockwise to increase idle. Adjust in small increments.
May 08, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
McCulloch ChainSaw Model: 600035-18. Looking for manual. Replacing the Primer Bulb and hoses to fual tank, carborator, and from opposite side of carborator are bad. replaced the lines connected to the...
Hi cmiller290...
The hose in the tank with the filter on the end connects directly to the carburetor input connection.
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
Aug 18, 2011 | McCulloch Garden
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
